Question about Brother SE400 Computerized Sewing and Embroidery Machine
Brother se 400 doesnt recognize that the presser foot is raised
I recently had my machine serviced, but when it came back it fails to recognize that the presser foot is being raised. This means that it won't engage or initialize the embroidery unit whatsoever. I've seen some resolutions around this site, but none that have worked to fix my problem.
  • Paul O Dec 01, 2012
    I performed percussive maintenance (hit) the machine on the top of the casing, above the lcd - Fonzie-style - and it began recognizing the presser foot position.... I'm not going to say that this is resolved, because I have no idea what hitting it would actually do, but it's working now.
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
  • 1788 Answers
SOURCE: I have a Brother SE-270 D how do I switch from
You can download your manual, downloads and a help section for free on the Brother website www.brother-usa.com. under the support section. They have a great site and very informative. Hope this answers your question. Good luck
Posted on Sep 13, 2010
app_3rp12471
SOURCE: "Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.1_9_2012_12_19_55_am.jpg
Posted on Jan 09, 2012
  • 1564 Answers
SOURCE: my brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
Posted on Jul 14, 2012
  • 1564 Answers
SOURCE: Presser Feet for XR-7700
Trust the Brother site and not the merchant.
Posted on Sep 19, 2012
How do I correct an erroneous "raise presser foot lever" message?
I would say it time to have the computer or sensors of the machine checked
Jun 04, 2015 | Brother PE-770 Embroidery Machine
How do I adjust the timing on Brother inovis 1500 sewing machine?
Clean the machine, especially the bobbin and bobbin case area and around the feed dogs. Take all the thread off the top of the machine, including thread off the spool pin. Raise the presser foot. Rethread the top with the presser foot UP, which lets the thread get between the two tension disks. Put the foot down to sew, and hold the ends of the bobbin and top threads together behind the presser foot for the first 2-3 stitches in each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551 I'm betting you're seeing something like the last two pairs of photos.
May 22, 2014 | Brother SE-270D Computerized Sewing...
Brother cs-80 tension issue
Remove the thread from the machine. Install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread. Set the upper tension to the midway point.
Insert the bobbin in the bobbin case (make sure it is turning the correct direction) and thread the bobbin tensioner. Install the bobbin case in the machine.
Insert the fabric under the presser foot. Lower the presser foot. While holding the top thread tail with your left hand, manually turn the handwheel (always toward you, never away!) one revolution until the top thread has pulled the bobbin thread up. Raise the presser foot and sweep both threads under the presser foot toward the back (you can use a stiletto, a pencil, or some other tool to sweep the threads). Lower the presser foot, gently hold both thread tails with your left hand and slowly turn the handwheel (either manually or by motor) to form a couple of stitches. Then let go of the thread tails and continue sewing.
If it continues to cause thread nests or you have other issues, then your machine may need service.
Apr 01, 2017 | Brother CS-80
If the presser foot lever is already lowered and on the screen is lower the presser foot lever. What is this?
try turning it off & then back on
I've encountered the problem with my electronic sewng machine
it jams up & I turn it off & then turn it back on, that usually clear the circuit board
if it keeps doing it, I would suggest taking it to be serviced
Jul 29, 2010 | Brother SE-270D Computerized Sewing...
XL tension setting
Hi - and welcome to FixYa. It sound like your machine is not threaded correctly. Here is the first rule: when you thread your machine, make sure your presser foot is raised up. Never thread your machine when your presser foot is down. When the presser foot is raised, the tension dials open and allow your thread to pass through the dials when you thread the machine. If thread is loose and hard to handle while you are trying to thread, just press down on the thread somewhere near to the top of the machine so it does not slide around. Here is the good news - when you have reached the needle, you can lower the presser foot. Before you thread the needle, pull your thread - if you threaded the machine correctly, the thread should not move. If it does move, you need to start over. If the thread does not move, you can thread you need with the foot up or down, pull the thread under your presser foot and pull it toward the back of the machine. Leave a 2 or 3 inch tail.
If you don't have your manual, you can download a free copy from the Brother web site. Brother manuals have very detailed, easy-to-read instructions. To get to the correct web page, use the link below:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/HomeSewingMachine/hf_xl3500t3510eus.html?reg=us&c=ca&lang=en&prod=hf_xl3500t3510eus
If you and other readers have a minute to rate my instructions, it helps me to better understand what folks need when they come to the FixYa site for help.
If you have more questions, or if the link fails, please feel free to comment and I will answer as soon as I can. Good luck, and have fun with your machine!
Dec 02, 2008 | Brother XL-3500
Presser foot lever
Hi and welcome to FixYa,
Initially, pls try a reset. This could be accomplish by unplugging the SE-270D from the mains. After an extended period, plug back in and power on normally. In some variations, there would be a reset button/key/switch.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 24, 2008 | Brother SE-270D Computerized Sewing...
CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
Make sure you're using the correct foot for the stitch. Is this during sewing or embroidery? Take off the bobbin plate using the screwdriver and remove the bobbin. Make sure everything is clean under and around the shuttle. If you've ever broken a needle the tip might have fallen down into the mechanism and occasionally be jamming it.
Nov 19, 2008 | Brother SE-270D Computerized Sewing...
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
I have a Brother LS 15 sewing machine
raise presser foot to highest level pulling wheel toward you(counterclockwise) release the foot assembly with the lever at the back of the foot holder assembly place you quilting foot in line with the slot on the shank lower the presser foot lever on the shank if it is where it should be the bar will snap in and you should hear an audiable click or snap let me know if this helps
thanks amy
May 12, 2008 | Brother LS-2125 Mechanical Sewing Machine
Dec 28, 2007 | Brother SE-270D Computerized Sewing...
Brother SE400 Computerized Sewing and Embroidery Machine Logo
49 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
