Question about Coffee Makers & Espresso Machines
The problem is when I use pre ground coffee beans. The water doesn't run through. It comes over the top and the grounds get in the coffee. I buy them that way because they mark them down half price. I
    Guru:
  • 887 Answers
There are whole coffee beans, and there are ground coffee beans, but there is no such thing as "pre-ground" coffee beans because you wouldn't want the beans to be ground AFTER making coffee.
If you have a problem using "pre-ground" beans, then STOP using pre-ground beans and grind them yourself.
I hope this helps.
Randy
Posted on Dec 01, 2012
EsWorld
  • 1618 Answers
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
It is possible that the grinds chute is blocked, remove the brew unit and check the chute from the grinder chamber, make sure that it is not blocked with coffee grounds.
Posted on May 31, 2009
  • 14 Answers
SOURCE: The grounds are sloshy and
I think I have the answer to this: when mine started doing the same thing, I found that coffee grounds had accumulated and were blocking the seal of the water supply with the brew-group.
The Behind the brew-group is a clear tube with o-rings that slides into the brew group to supply water. One or both of these is clogged with accumulated coffee grounds. Try cleaning out both well.
-tony
Posted on Sep 28, 2008
  • 7 Answers
SOURCE: PUT BEANS IN GROUND COFFEE SECTION
Open side panel and clean machine as described here:
http://www.fixya.com/support/t2900087-bosch_benvenuto_tkn68e75_coffee_maker
Cheers!
Posted on Sep 11, 2009
espressonist
  • 1711 Answers
SOURCE: Water (coffee) does not make it out through the
Propably the vibrating water pump is the problem.
It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water. Then try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Posted on Mar 25, 2010
Testimonial: "Brilliant, I cleaned the shower head as you instructed and it's working perfect, thanks for the tips. Louise"
SOURCE: ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
Posted on Jul 31, 2010
Slow water dispensing
How slowly in comparison to other units? Have you measured it how fast it runs ?? If slower than when Syntia was brand new is maybe caused by an insufficiently cleaned brew group or lack of proper descaling .Calcium or mineral in the unit's lines and boiler can slow down your machine .
if the filter screen is partially blocked from old coffee tar then water cannot flow faster . In my opinion it always runs slowly when rinsing .
If you use a "Coffee Residue cleaner "only use it in the pre-ground
setting chute and use only a pinch at a time . then run pre-ground setting without any grounds and run another one to clear the detergent
Very oily ,sticky coffee beans can plug up any late model superautomatic's system as you can read in the unit manuals . Because the laser cut holes in the fliter screen are so small that any coffee tar will not flow properly through the screens .I have had many machines which had to be switched to a less oily bean to work more than for2 or 3 cups .When beans are roasted too fast and too hot ,the coffee oil can turn to coffee tar .
My Xelsis unit cannot handle very oily beans . 2 cups and it STOPS
I only use beans roasted to American Coffee institute recommended procedures .
Aug 30, 2014 | Saeco Syntia Espresso Machine & Coffee...
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
My Coffee Gaggia Vision is grinding and the coffee is coming out very weak. The billet coming out is very wet and small. Any solutions or ideas?
see this matter causes:
Make sure there's water in the unit's water tank.
  • 2 Unscrew the shower disk from the top of the unit and rinse it. Dry the disk and screw it back in place.
  • 3 Replace the coffee grounds with properly ground beans. Coffee beans that are either too finely or too coarsely ground will adversely affect the flow of coffee from the machine.
  • 4 Make sure the coffee in the filter is not packed too firmly if the coffee isn't flowing at all. If the flow is too fast, tamp the coffee down a bit more with the tamper.
  • God bless you
    Jul 18, 2012 | Gaggia 90950 Platinum Vision Espresso...
    There is no water coming out of the machine at all. No error light come on but when you go to make a coffee with beans or pre ground it goes through the process but just dry coffee comes out. Also no water...
    For the steam check the end of the nozzle to make sure it is not blocked.
    For the coffee run a coffee using the pre ground method but without coffee grounds, if water comes out then grinder is too fine, if no water remove brew unit and clean top shower screen, you might have to clean tube leaving from shower to discharge.
    Aug 29, 2010 | Gaggia Syncrony Compact Coffee...
    Gaggia Platinum Vogue Built in Grinder
    Just use the whole bean. Using pre ground coffee through your grinder will screw the blades completely.
    However if you have a decaff option that allows you to put coffee directly into the brewer that would be ok........just dont put it into your hopper that feeds the grinder.
    Mar 03, 2010 | Gaggia Platinum Vogue 90800 Espresso...
    Magic Comfort machine won't make one cup of decaf coffee
    Make sure to use pre-ground coffee only (MEDIUM
    ground) and not soluble coffee.
    Question- check to see where the coffee is going- did it end up in the brew group- but you did not get coffee? Then, the filter is clogged. Clean the filter. If you have used oily beans, they can clog filter easily.
    Jun 19, 2008 | Coffee Makers & Espresso Machines
    Bypass doser malfunctions
    Happens when the preground coffee is not ground fine enough, you may have to put the pre ground coffee in a manual coffee grinder to make it finer. The machine is not really designed to brew regular coffee grounds.
    Jan 20, 2008 | Saeco Magic De Luxe Espresso Machine
    Coffee Makers & Espresso Machines Logo
    341 people viewed this question
    Top Coffee Makers & Espresso Machines Experts
    Kolbrun...
    Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
