Is their any battery in the goodman furnace - Heating & Cooling
  • 407 Answers
No batteries, but it will have a capacitor (which is like a battery) on the indoor blower motor.
Posted on Dec 02, 2012
My goodman GMVC95 furnace circuit board is flashing On 6 I replaced the flame sensor but it's still flashing. Does it have to be manually reset?
Alright, have you checked the low voltage fuse on the circuit board in the blower compartment? Make sure you check the roll out switches as well. If all of these issue appear to be fine then you may have a bad circuit board. There has been a bad batch of circuit boards going around many of the popular furnace brands this winter. Trane Gas Furnaces and Goodman Gas Furnaces have been effected. We sell both brands and have had to replace many circuit boards on new furnaces. Trane Gas Furnaces Installed Goodman Gas Furnace Installation Gaithersburg
Feb 03, 2018 | Goodman Heating & Cooling
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
Why would my Goodman LP furnace CAPF1824B6CA hum, but not kick on?
most furnaces no longer have a pilot, they are all electronic ignition. first thing to come is the inducer motor. if that is what is humming, then either the run capacitor is shot, or theres an issue with the motor itself
Dec 24, 2014 | Goodman Heating & Cooling
I have a GDS80703AXBA furnace by goodman but furnace wont ignite
Here is a tip that will help you try to figure out why your furnace is notworking.
BasicFurnace or Heating System Troubleshooting
heatman101
Sep 28, 2011 | Goodman GMS90703BXA Heater
Furnace wont run ...thermostat battery went dead i replaced the batteries and still furnace wont run...We recently had a power outage for approximately 12 hours. This furnace is in our garage. we had...
Hello, The first thing you need to check with a multimeter is if you are getting 24 volts between the R AND C terminal on the intergrated control board. If not than the transformer is blown and needs to replaced or the fuse on the control board has blown and will need to be replaced. When check for 24 volts at the R and C terminal make sure the door switch is pushed in, u can just use electrical tape to temporaily hold the switch in. If you are getting 24 volts at R and C and notthing continues to run than the intergrated control board is most likely the cause and must be replaced.
Feb 04, 2011 | Goodman GMS90703BXA Heater
Is goodman a good furnace? What about if I compare it to a trane furance?
goodman makes a very good furnace and just as durable as a trane at a fraction of the cost. i'll stand behind goodman just as i would a trane.
Nov 26, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
