My goodman furnace just like doesn't ignite because it light and then no fire coming up and then it stop. please help me
  • Robert Dec 02, 2012
    If the igniter glows, the we need to make sure that the gas valve is opening
    Genius:
  • 1,033 Answers
If the burners ignite and then turn off it looks likemthe flame sensor is the problem. On the opposite side of the igniter in the burners will be a metal rod, this rod needs to be cleaned with a steel wool pad. Once it's clean turn Furnace back on.
Posted on Dec 01, 2012
WebTeligent
  • 42 Answers
SOURCE: No heat, trouble shooting light has continious flash.
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Posted on Nov 10, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMS90904CXA Wont ignite, light blinks 3 times
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
Posted on Oct 21, 2008
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
heatman101
  • 43501 Answers
SOURCE: Burner ignites and goes out (Goodman Gas-fired furnace)
The problem you have is water in the exhaust pipe.
Check to see if the pipe has sagged anywhere or if there is a trap in the line.
If you hear gurgling then it is definetly water....
Some times can be hard to find, even a pipe 1/4 full will cause problems. They are very sensitive to flue problems.
Make sure that the flue pipe either runs back to the furnace or out to the outside, a continuos slope either way witha high spot in the middle.
Also check the bottom drain of the blower if it has one, have had them plug and trap water also..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 24, 2009
  • 288 Answers
SOURCE: Goodman furnace burner ignites then shuts off in about 10 seconds
if you have replaced the flame sensor and it will not stay lit, the draft safety switch may be opening. It works on positive and negative pressure created by the inducer fan motor.You may have a restriction in your heat exchanger or if is a high efficiency furnace, it may not have the drain tube installed properly with a trap. The trap works just like the trap under your sink and if water isnt in the trap, the pressures can be effected enough to open the draft switch(some call it an air pressure switch)
Posted on Jan 07, 2010
Model gch90703bxab
There could be other problems but check and see if your igniter is not burnt out. Ours did that and tried to ignite for two days and then I found I had to change the igniter.
Dec 05, 2017 | Goodman Manufacturing Goodman GMH950704CX...
Furnace will not light,on Goodman Furnace model#GME80704BX
Is the gas turned on or does it come on but goes off quickly?
Oct 06, 2012 | Cozy Enclosed Front Console Heater 70,000...
Goodman GDS80703AXBC Flashing 6 times. Replaced Limit, Flame Roll Out, Flame sensor, Ckecked Flue. Furnace used to ignite then shut down flashing 6 times. Used central air over summer just fine. Now...
Per Goodman installation manual:
Misaligned burners, blocked flue, induced draft motor failure. I'd check the inducer first. Up top you'll see a small motor. Near it youll see a small ruber like hose. That hose goes to a round safety called an air proving switch. The end of the hose that connects to the metal, remove it and make sure the metal hole is not stopped up. Make sure the hose is clear and not kinked. Make sure the induced draft motor is working, should be the first action in a series of operation during heat. The air proving switch should close during normal operation, has 2 wires that are connected. Check all wires for loose connections, while the furnace is unplugged and no power present. Make sure everything is put back where it belongs and try it again. Most of these issues are IDM related but I have seen the rollouts open due to burners firing towards the wall of the unit, instead of into the opening of the heat exchanger. Work safe and I hope this helps!
Sep 30, 2017 | Goodman Heating & Cooling
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
My goodman furnace 80703 fan comes on ignitor glows burner starts , cuts off in 10 secs,furnace starts cycle again. home no heat
I am not a furnace tech but, there are several inputs to a gas valve. There must be an 1) electrical/mechanical indication that there is a draft fan running (to move potentially explosive gas so it doesn't accumulate), 2) adequate gas pressure to the valve, 3) the thermostat must be calling for heat 4) and electrical indication that there is an ignition source. In your scenario, you have the source of ignition, the gas valve is picking up the burner but the gas valve believes there is something missing so it shuts off the gas to the burner. In this case, I suppose you might not have enough gas pressure (is another gas appliance running or is the line to the furnace too small?), a thermocouple probably isn't the problem since the burner wouldn't pick up if the gas valve didn't believe the ignition source wasn't good enough. You could have a plugged chimney or exhaust pipe if it is direct vented since there is also a pressure switch that detects whether there is enough draft once the burner picks up. Really should call a furnace person especially if you don't have a carbon monoxide detector that you trust. If you think you are capable of continuing, you could jumper the various inputs the the gas valve one by one until the burner picks up and stays picked up. Whichever terminals you jumper that accomplish this, is the culprit. Look at the schematic on the side cover to the furnace for this information. Hope this helps...
Oct 01, 2011 | Goodman GMS90703BXA Heater
Furnace GMS9/GCS9 Cycles twice and then fires up most of the time and then it won't fire and shuts down. To restart it We have to shut the 110/115 power off for a few seconds and turn it back on and it...
Furnace ignition controls will attempt to light the furnace 3 times with several minutes delay between each attempt. If it fails to light or the ignition module fails to detect it lit after the 3 tries, the module will lock out and require a "Hard Reset" to try again. It is a common feature in nearly all newer furnaces intended to let you know you have a serious problem. You should call a service technician for this because there are a number of things that may be causing this flame failure. Please grade my answer on how much I have helped you. Thank you for the opportunity. Roger
Apr 04, 2011 | Goodman Heating & Cooling
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Ignition failure after three attempts then sits for an hour.
try cleaning the burners and or adjust the distance the igniter is from the actual burner .
Oct 01, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman GMP075-3 ignition problem
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
