Question about Hitachi Gst Hitachi CP-RX80 3LCD Projector
Does it choase any problems if its up side down
Does it chase any problems if up side down
    Champion:
  • Hitachi Gst Expert
  • 225 Answers
It's not supposed to.
Posted on Dec 06, 2012
My headlight on my 2005 kawasaki vulcan 800 classic won't turn on I have checked the fuse box twice and the fuse was burned up both times. Would this be the junction box?
Pull the headlamp out then replace the fuse. If it doesn't blow the fuse you new a new headlamp. If fuse blows start inspecting the wiring, it might have gotten pinched or frayed somewhere and this is causing the fuse to blow.
Apr 03, 2015 | kawasaki Motorcycles
Front windscreen wiper not working
ask your "local garage" to get off their lazy butts and chase the problem down with a test light or volt meter. were the voltage stops is where the problem is. provided the linkage is in working order the only way to fix this is the chase it down as such. it could be anything from a faulty ground connection to a corroded section of wiring to a faulted terminal connection
Mar 15, 2012 | Cars & Trucks
I have a clinking from the near side suspension when going over a pot hole
Recently ran into a similar complaint and we chased it for quite some time. Ended up being the nuts were not torqued down on the strutts and there was some play in it. Finally found it by having a heavy friend stand on the bumper and jumping up and down.
Jun 23, 2011 | 2000 Jaguar S-Type
99 ford contour A/C fuse burnt in socket...need to find the 2 wires to bypass with inline fuse, driver side fuse panel? help?
Somthing doesnt sound right here, someone must of installed a bigger fuse than whats called for, i would have the system checked to see why its drawing so much amperage, you will need to remove the fusebox and chase that wire, you want the ac side of the wire not the hot side, if you are reusing the power wire then okay chase them both, but you will need to chase them into box, use an ohm meter with a continuty test on it to locate the right wires,okay i just found a wiring diagram, the fuse is on the driverside fuse box , okay the wire you are looking for is violet/purple and this is for fuse location #37 which holds a 30amp fuse,the other wire is a power wire and should be red,note there are a lot of hot red wire so try to use the same one by chasing it.
Mar 23, 2011 | 1999 Ford Contour
My drivers side turn signal stoped working. I replaced the bulb and it worked for a few days then stoped again. I checked the bulb and it didnt blow. Also checked the fuses and all seem to be good. Tried a...
You are going to have to check wiring. Many it is the socket. If you have a test light or meter you can measure the voltage.
There are several turn signal lights, front, rear, side, etc. Do any of them work on the drivers side? if not then it may be the column switch. If only one light is out, then it will be wiring somewhere. Chasing wiring problems is as hard as chasing hydraulic problems, requires patience and starting at one end and continuing till you find the problem.
Good luck, Jim
Feb 23, 2011 | 2005 Saturn ION
How to choase a good clutch kit for a camaro 2000 ls1 (manual) with 350 hp in wheel?
I run 500+HP camaros and the clutches I use are from Summit Racing Equipment A little more money up front but there is alot less slippage and more power to the ground.(www.summitracing,com) or 1-800-230-3030
Feb 28, 2010 | 2000 Chevrolet Camaro
What is the procedure for sighting a zeiss z-plex reticle scope?
mount it, get a 100 yard target, and you have to chase the bullet right is left up is down
Sep 07, 2009 | Zeiss Conquest w/Z-Plex Reticle/Side Focus...
71 sportster stops running
sounds like a ground problem. make a jumper wire and hook one end to the ng side of bat. the other to a good metal prt of engine. if this cures the prob start chasing down your ground wire making sure all connectsions are clean and tight
Sep 07, 2009 | 1979 Harley Davidson XLS 1000
Passenger side headlamp wont light up
I'm assuming globe means bulb. I have replaced many bulbs that look fine, and that turns out to be the problem. But to stop you from chasing down a problem that isn't there, test the connector that attaches to the bulb. Should be power there with the head lights on. There should be a fuse, and a relay. The fuse is under the dash or on the side of the dash near the door hinges, I'm just not sure if this car would have seperate fuses for L headlight and R headlight. But you should check power first at the connector.
Feb 26, 2009 | 1990 Mazda MX-5
Upgrade software
LIBERACION DE SAMSUNG SGH D900
Jul 27, 2008 | Samsung SGH-D900 Cellular Phone
Hitachi Gst Hitachi CP-RX80 3LCD Projector Logo
18 people viewed this question
Top Hitachi Gst Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Gst Office Equipment and Supply Expert? Answer questions, earn points and help others
