Question about Swisher Garden
I need a cable for a Swisher RTB105441 mower with remote engage.
I cannot locate the cable on the IPL. I have found the clevis on both ends, but need the part number for the cable. Any help would be appreciated.
  • 376 Answers
SOURCE: the spring thats at the end of the mower deck
If you're refering to the cable that runs from the lever on the dash down to the deck and the spring end slips over the bolt on the idle pulley, yes, you need to replace the whole cable. It's one piece. Part # 175067. Dwain
Posted on Jun 10, 2009
  • 67 Answers
SOURCE: Can't pull choke knob up on my riding lawn mower
take the cable off the mower and clean it in a pan with solvent or brake cleaner spray. you can coil it up to fit the pan while soaking. afterwards, let dry --- if you have an air compressor blow it dry to help clean and dry it --- then oil it up with a light oil or wd-40, wipe it off, stretch it out, and work the cable again before you remont it. the cable will stick if it gets too dirty and has no lubrication. may want to buy a new cable but they usually can be cleaned and lubricated.
Posted on Jun 25, 2009
mowerman1857
  • 389 Answers
SOURCE: i need a belt diagram for a 60 inch Swisher lawn
There is a good repair manual here:
http://www.manualnguide.com/dl/3425/
Posted on Sep 22, 2009
bbreton
  • 437 Answers
SOURCE: need the belt diagram
Go to swisherinc.com. Look under customer support, support/manuals.
You should find what you are looking for there.
Posted on Oct 07, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
How to replace engage cable
Nearly all cables are attached with a hook end and a screw.
Loosen the screw and carefully unhook the cable. Reverse this to install your new cable.
Nov 03, 2015 | Swisher Trailcutter Mowers
Can a bad battery cause clutch to slip?
Not likely. But to eliminate that possibility try connecting a battery charge to the battery and try engaging the blades then. Also check all electrical connection in system for corrosion and tightness. Lastly With compressed air blow all dirt and debris from the mower, especially clutch area and Hydraulic pumps. Check tension on blade drive belt.
Aug 17, 2014 | Swisher Garden
Adjust belt tension and brake linkage on Swisher 44 in 11.5 HP mower
is the belt tension adjustment on the lever that engages the blades?
Mar 29, 2013 | Swisher Garden
I need a cable for swisher mower 60 in deck , cable supports cutting deck and helps level deck
Buddy of mine is a Swisher dealer give him a call 1- 920 - 841-7654 This is a Wisconsin number Im sure if he has one he can ship it or give you a name of someone closer.
Apr 10, 2012 | Swisher Garden
My swisher zt blows the fuse every time i engage the blades...can get the engine to run and drive. problem is only when i start the blades. any ideas?
Check the all wiring from the engage blade button back to the electric clutch for worn spots that may be grounding out on the frame.
Sep 17, 2010 | Swisher Zt2560 Zero Turn Radius 60" Riding...
I have a swisher ride king mower that keeps shredding belt from moter to deck. dose anyone have solution?
I have been told if the parking brake is engaged and you try to drive the mower it will instantly put a burn spot on the belt. I hope this helps.
Aug 11, 2010 | Swisher Ride King Zero Turn Mower 23 Hp,...
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
Dec 06, 2009 | Ariens Garden
Cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Garden Logo
32 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
