Question about Pioneer VSX-516-K/S Amplifier
How do i connect non passive woofer
I have a woofer that i am trying to connect to the above amplifier. the problem that i have is that there is on jack at the back of the amp but i have to bare wires that come from the woofer. i have tried putting a jack on the end and plugging it in but the amp recognises it but no sound will come from it been trying for 2 weeks now and pulling my hair out. can someone please help
    President:
  • 3,130 Answers
This receiver can only take a self powered subwoofer I'm afraid. You could get a power amp and power the sub like that but in the long run I really think you would be happyer to get a new subwoofer. Good Luck
Posted on Jun 07, 2007
SOURCE:
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
Woofer has stopped working
Check the back side of the woofer. they are frequently designed with protection fuses to prevent failure.
Mar 07, 2018 | Bosch Kitchen Ranges
I have samsung psws610e sub woofer system. it has not a power in put cable or amplifier. how to work it? pleace tell me.
First the subwoofer is passive so there isn't any power,if it were active it would have an amplifier so use your receiver as one.So just connect the unit to your sub out on your receiver using the left and right out puts if your receiver doesn't have wire out puts you can plug it into an aux speaker out put.
Nov 26, 2010 | Computers & Internet
Old receiver, new subwoofer- how to connect?
NOOOOOOOOOOOOOOOOOOOOOOO! Never connect speaker outputs to anything that looks different, like RCA connections. Can you say crispy critter?
Your receiver sounds like it won't send specific Subwoofer of Low Frequency Effects information to the Sub so we're cheating by adding a sub. If you named the model of each we may have a better shot at naming the output you need to use.
I'm curious. How did you have the old passive sub working?
Basically what you may have to do is feed (probable) full range audio to the Sub using an RCA splitter to combine the L and R outputs found, oh, at any Tape Output that you're not using. The Sub will only reproduce what it can. The presence of higher frequencies won't bother it. If it has its own volume control you'll be able to balance its volume with the rest of your speakers.
Mar 18, 2010 | Audio Players & Recorders
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Need apair passive crossover for pair of maxp64 600 watts
You can easily make one yourself. All you need are two non-polar capacitors of about 1 Farad each. Radio Shack and any respectable electronic component store have them. For a high pass filter (AKA crossover) connect in series with the speaker wires. For low pass operation like a sub-woofer, use it in parallel with the speaker.
Oct 02, 2009 | Car Audio & Video
Is denon 1356 with active bass. and i want to know the difference between active bass and passive bass.
Hi....
A passive bass is a box with a sub-woofer in it.
An active bass is a box like that with an amplifier built in.
Hope that helps.
Check the Denon site too
Dec 26, 2008 | Denon AVR-1803 Receiver
Kenwood LS-P5000D home speakers
Hi cw10k
Can you tell me what the diameter of the hole for the passive radiator is. I think I can source one for you. Let me know and we shall see.
regards
robotek
Jun 17, 2008 | Audio Players & Recorders
Eltax DR-110 Sub-woofer issue
Where have you connected the sub's leads?
Feb 26, 2008 | Audio Players & Recorders
204 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
