Question about Fisher and Paykel DGGX1 Electric Dryer
Need to replace the jockey pulley kit on a fisher paykel dryer
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
  • 20 Answers
SOURCE: fisher paykel dryer DE04-US6 just get a buzz sound
Open up the door and push the door switch and hit the start button and try to turn the drum by the baffle in the dryer and it it starts to go then you need a new motor.
Posted on Aug 20, 2009
Testimonial: "Held the door button in...pressed the start button...spun the dryer drum...and it started spinning...i.e. bad motor. nice work thanks"
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Posted on Nov 08, 2009
SOURCE: need a manual for fisher and paykel drier ED56
try here http://kitchen.manualsonline.com/ex/thread/view/idThread/2200997
cheers Sandy
Posted on Jul 02, 2010
SOURCE: my fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Posted on Jul 16, 2010
Where can i find a cheap rebuild kit for the pump on a WA37126EW2 washer
If you search Ebay for "Fisher Paykel 420325P Water Pump" I did find one pump for $59. Good luck.
Dec 07, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Aerosmart dg62t27dw2 belt squeeking and making clothes stink
Your belt is not on the pulley correctly. You will likely need to purchase a new belt as the damage has likely been done. Remove back cover and then remove casing (video on youtube) Replace belt. You may be able to fix quicker by flipping dryer on side and replacing the belt from the bottom, but it is a tight fit.
Jan 12, 2014 | Fisher Paykel Fisher & Paykel AeroSmart...
I have a Fisher Paykel dryer that is squeaking badly. Is there a oil/grease port?
There is a drum bearing kit which could have failed or also the belt drive pulleys could be squeeking.
Best to get them replaced.
Can't oil or grease them.
Ash
Sep 11, 2011 | Fisher Dryers
The dryer is squeaking/squealing during operation. It is a high-pitched noise that is rather loud. It is also getting very hot. We vacuumed the lint bucket area behind the cover, which fixed the...
I am having a similar issue. I had a tech out to look at it and he recommended replacing the drum bearing and idler jockey pulley. ($419.95) Ouch. I am going to do this on my own. I ordered the part from paykelfisherparts.net. Part # 479332 Drum Bearing Kit $79.91.
Check here for more info. This was exactly what I found on my machine (DGGX1) http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/731-fisher-paykel-dggx1-top-load-dryer.html
I did not totally trust the repair dude. He was wierd and not very thorough. I can tell the bearing is bad, if there are still noises I will order up the jockey pully thing and see if I can figure that out.
Here is a link to the service manual. (https://docs.google.com/fileview?id=0B5If-wTgYWH5OGNkY2RmZDEtMWU4OS00MjgwLTg3OWEtMmRlZjY0N2I5MzYy&hl=en)
Good luck
Jan 17, 2011 | Fisher and Paykel DGGX1 Electric Dryer
I need to convert from NAT GAS to LP gas. Is
Get in touch with fisher and paykel. They should be able to supply you with a kit if one is available. http://www.fisherpaykel.com/
Dec 01, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Squealing Fisher Paykel Dryer DE05-US2
dryer's have a long belt that runs around the drum. a common culprit is an idler pulley on the belt tensioner. you can take off the front of the dryer and oil it for a temp fix. it will probably need to be replaced
Dec 16, 2008 | Fisher and Paykel DE06 Electric Dryer
Venting a dryer outside
What do you need to reverse?
I understand that the wall kit is to blow the heated air from the dryer to outside therefore not humidifying the laundry.
Are you trying to draw air into the dryer from outside or blow the air outside?
Sep 14, 2008 | Fisher and Paykel DE06 Electric Dryer
It wont heat at all. lint trap empty, good air flow
needs a heater rework kit probably. contact fisher paykel and they will pay for the repair.
Nov 02, 2007 | Fisher and Paykel DEGX1 Electric Dryer
F&P ED56
see if the jockey arms are hitting the drum or the capacitor is losse (if the dryer is upside down).hope this helps
Oct 20, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DGGX1 Electric Dryer Logo
32 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
