Ipod classic won't turn on, battery with lighting bolt when plugged in.
  • 3 Answers
You probably need to reset your IPOD. Here are the directions:
1. Unplug the IPOD from the power source.
2. Slide the hold switch or button to HOLD and back again.
3. Then press the MENU and CENTER buttons at same time until the Apple logo appears.
You should be back up and running. If not, try again and remember to make sure you press MENU and CENTER buttons at the SAME time and continue to hold them down as long as it takes for Apple logo to reappear. I once had to hold them for more than a minute before an IPOD touch would reset.
Posted on Dec 01, 2012
My ipod classic 7th generation is frozen. the light is on but it doesn't respond to any buttons or the wheel. I tried to press the home button and the play button but it's not doing anything.
Hi! (: i'm not sure if this will work, but when my ipod did this, I left it in a cup of rice for a few hours, then I left it charging for a while until it turned on and showed the home screen. If this doesnt work, try calling apples technicians on their website! They can help sometimes..
[Also, yahoo answers might have a better solution] Good luck!
Dec 04, 2012 | Apple iPod classic 7th Generation
My 2004 Honda Pilot ran fine then a hour later won't start. At first thought battery so we charged up usig one of those chargers you plug in. Lights flicker, and clicking sounds but won't turn
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
Sep 24, 2012 | 2004 Honda Pilot
I have an ipod that won't respond respond to touch or turn on past the very low battery stage. what do i do?
Connect the supplied USB cable to the IPod and plug it into the computer's USB port. The computer will then charge the IPod.
Aug 27, 2011 | Computers & Internet
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
I have a silver ipod classic 16GB, and it was my cousins but he rencently got an iPhone so gave his classic to me. Im not sure how long he has had it for but when i started using it the first time i...
Yes, This problem is generated by battery. If Battery is dead iPod Could not start.
Contact Nearest apple care center & replace Battery of your iPod & i will start.
I am very happy to assist you.
Thanks.
Oct 10, 2009 | Apple iPod classic MP3 Player
My jbl radial, when using a 120 gig ipod, will skip songs.
Not a solution but mine sometimes causes my ipod to skip mid-song to the next song or podcast as well. JBL customer service is usually good and I've been meaning to check with them since I finally figured out it's the radial and not my ipod.
Jun 21, 2009 | JBL Radial Speaker Dock Docking Station...
IPod 30 GB stopped working
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If there is no effect, then you have to contact apple, or your dealer for repairs, becouse a part is most likely damaged.
If you need more assistance let me know. Good luck.
Jan 13, 2008 | Apple iPod MA446LL/A MP3 Player
103 people viewed this question
 Grubhead
Grubhead
