Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Cannot recieve a internet signal from router wired and wireless
The router indicates that i have a signal but the company(ISP) cannot dectect the router
  • abcasl Jan 12, 2009
    Belkin worked fine last night. We unplugged everything due to storm activity. Tonight I plug in Belkin and I cannot connect to internet. I plug in my cable modem and can send this message. Please help!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Are you getting DHCP from ISP? If not ask them if you can static the address in your router. then do ping tests.
Posted on Jan 11, 2009
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
I have had a LinkSys WAP54G wireless router for 1 month The signal strength has always indicated very low. Is there anything I should /could do to improve this. Interestingly the other wireless...
HI, If its a Internet link which u are speaking about, Please connect the LAN to the System with LAN wire and check the speed. the Problem will be due to low connectivity issue. Wireless router will not increase the bandwidth, it can able to provide the same or below the bandwidth which it received from the ISP.
Mar 01, 2011 | Linksys WAP54G (WAP54G-UK) 802.11b/g...
I have a Cannon MX 850 all in one. My Fax is not sending upon receiving the fax signal from a long distant account. The number rings through, the signal begins, it rings once then stops. The local fax's...
REREINSTALL VIA A WIRELESS CONNECTION FIRST THEN ATTEMPT TO REFAX
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 25, 2011 | Canon PIXMA MX850 Multifunction Printer
Adsl wont stay on ,quick set up ,says cant find modem
Either the router is not connected properly to the modem, or the modem is not set up properly. First, unplug the router from the modem and disconnect power to both of them. Make sure the modem is connected to its data source, in this case the telephone line. Make sure the company has authorized the modem and make sure it's connected to the phone socket they specified, if they did. You should plug a CAT-5(ethernet) cable between the LAN port on the modem and the WAN port on the router. Now power on the modem. Wait until the modem's lights indicate it has a connection. If the modem doesn't indicate a connection, call your ISP. It will probably be as simple as them sending a refresh signal to it. After the modem finds a connection, power on the router. Your internet service should now be working. If not, try plugging the computer's network cable directly into the LAN port on the modem. If that computer then has internet, your problem is with the router. If the computer still doesn't have internet, then the problem is either with the settings on the computer or there's still a problem with the modem/ISP
Feb 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Need nat type 2-PS3 Cable ISP digital phone modem wireless route
you can put your ps3 in a dmz zone. if still does not work its not your router. u can keep your ps3 in dmz and get your router to open ports. u can call your router company. If still does not work its not your router more than likely. It might be your modem. i have at&t and that was my issue. i went to dmz on modem and allowed it to pass through dmz zone and ip addresses to pass through. but make sure on your comp u have spyware or something. Your ps3 can not get virus.
Sep 06, 2009 | Netopia (3347NWG-VGX) Wireless Router...
Y have problem whit the internet it to slow
dude that is in terms if your ISP.
but before you call your isp try to do this:
Scan for viruses ( but first update the antivirus software you use to the most updated virsion )
CMD codes ( Cant connect to Internet )
1. Go to command prompt
2. Type-in Ping 127.0.0.1 = Lan Card address
3. Get the value of the pockets Sent, Recieved and Lost.
4. If the value is ( Sent = 4, Recieved = 4 and Lost = 0% ) Then the lan card and wireless card is working fine and the problem is with the ISP = Contact ISP
OR
No Connection using router
2. Type in ping 192.168.0.1 or which ever the address of your router.
4. If the value is ( Sent = 4, Recieved = 4 and Lost = 0% ) Then the lan card and wireless card is working fine and the problem is within the Router configuration. = Advice the CX to Contact the Router manufacturer or ISP
Aug 21, 2009 | Acer Aspire One PC Notebook
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
Belkin router
it is possible that the settings for your ISP is already gone or the router is not recognizing the settings.
Oh by the way who'se your ISP, is it cable or dsl internet?
For cable internet the router's internet/WAN connection type must be set to "Dynamic" for DSL internet there are some that will require you to setup your userID and password given to you by your ISP, to do this just change the connection type to PPPoE and fill out the required fileds(usually it just the userID and password from your ISP).
To access your router setup page, just open internet explorer on your computer(given that its connected wireless or wired to the router) and type http://192.168.2.1 . Type admin for the password and leave the password blank.
Jul 15, 2008 | Belkin (F5D5231-4) Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
