Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
Left door plastic locking peice broke
The left door plastic piece that runs the length of the door is broken this piece "locks" the door securely it has wires inside as well
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Here is the complete parts list for that unit. You can order directly from the supplier and all parts come with a 365 day, any part, any reason return policy.
Posted on Dec 01, 2012
Dodge journey rear hatch wont lock. When you lock the car all the doors lock but you can still open the rear hatch
I would guess that either the wiring to the hatch lock is broke, or the lock or linkage isn't functioning. Have someone stand at the back of the car when locking the doors and listen for the latch actuator to click, if it does click then it's probably a broken plastic piece on the linkage, if it doesn't then either you have some bad wiring or the actuator itself may be bad.
Oct 25, 2016 | Dodge Journey Cars & Trucks
Mazda 1996 lx prestige passenger door lock dose not work ether with key button our buy pushING down on
Need to take inside door panel off and look at inside door latch. The locking rod probably broke at door latch. Or it lucky unhooked. To find whice rod it is. You may need to cut hole in platinum sheet near door latch. Then move one left to right. One will lock it and one will open door. Then check to make sure both ends are connected on the lock rod. Almost sure it is the small plastic piece broken of door latch. And when taking inner door panel off. Make sure all screws are out. And use flat screw driver next to plastic tabs to pop them out. If careful everything will go back together easy.
Jul 11, 2016 | Mazda Cars & Trucks
How do I fix the Left side Sliding Door on my 2007 Dodge Grand Caravan?
have the hinges dropped or a catch remained locked in placem sounds like it. The door should be removed for inspection and diagnosis repair, somebody who repairs such vehicles would probably be the place to sort it out.
If your mechanical/electrical skills are upto par you might do it yourself....sounds like a mechanical issue really
good luck
Jul 03, 2015 | 2007 Dodge Grand Caravan SXT Minivan
We take turns replacing microwave ovens where I work. The latest one, a GE JES1358WL, stopped working after opening the door while running on a one-push (1 minute) start setting, and the control panel is...
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Nov 04, 2010 | GE JE1235 Microwave Oven
Back hatch will not open can hear the moter but wont open
There is plastic contacting metal for the window release the plactic piece breakes you have to slide a hanger between the panel and the door until it pops open. Then you remove panel and replace tailgate lock solenoid. The part is about $35 at rockauto.com. you cant replace just the plastic peice that broke.
Mar 12, 2010 | 2000 Chevrolet Blazer
The alarm on my 2003 acura tl randomly goes off once it has been set. Any cure?
Have you checkd your fuses & also there is a small plastic/rubber piece somewhere on the driverside door, either on the actual door or on the car frame itself that once u close the door, that peice tells the alarm that its ok to lock and arm. (i dunno if u noticed but u can manually lock ur car w/ ur keys in the ignition, running, only if driver door is closed, from any other door usung the lock button, but not if the driver door is open) If that peice n ur door is worn, eventually it will break causing u to have to use ur key to unlock ur car. BUT, doing that will not disarm the alarm only unlock ur car & it will sound every time & not stop until u pull the fuse to the horn & lights. i had to bring mine to a dealership to get it fixd bc I couldnt figure it out. Paid $300 for a $25 piece of plastic I could have changed myself. Hope this helps..... good luck.
Aug 23, 2009 | Acura TL Cars & Trucks
Electric door unlock does not work on one door This is the left rear door and it does not work with either remote or button on driver's door
Could be 1 of 3 different things. #1 the electronic solenoid that controls the lock mecinism has failed. check by feeling/hearing a click in the door when you try to lock/unlock. if you hear the click from that door it means that the linkage is broke or has come apart. If no click it is the solenoid or loose/broken wire. Chances are if it is a broken wire it will be in the plastic tube that runs from the frame into the door.
Jul 31, 2009 | 2004 Ford Freestar
Broken door lock on a 1997 Saturn
The rod may have gotten bent causing the plastic clip to break. Strighten out the rod so it has it's length again to push on the luck to unlock the door. Good luck and hope this helps.You don't have to remove the rod, you can do it in it's place with your fingers.
Jun 17, 2009 | 1997 Saturn SL
Ignition switch locks when remplaced the Stop Light & Horn fuse
Sounds like wiring. The key won't release unless the car is in park. From what I can remember the solenoid that controls the shifter lock is on the same circuit as the horn. Since the fuse was spent I think somthing must be shorting out. Take the centre console out and check for burn and or touching wires by the shifter.
Jan 08, 2009 | 1995 Honda Accord
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
88 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
