Question about ViewSonic VA712B 17" Flat Panel LCD Monitor
VA712b - display disappears within 5-10 seconds. Recovers for short time by PC reset or monitor power cycling.
I am an experienced hardware engineer, working on DTV projects for the last 7 years. I have a 17" LCD monitor Viewsonic VA712b (Model number VS10901, S/N PX7062700927), which I purchased in California several years ago (the warranty is not valid any more). Since yesterday the display disappears within about 5-10 seconds. Playing with the VGA cable does not recover the display. The display appears when I reset the PC and by toggling the monitor state to STBY and back to ON. In both cases it disappears after short time. I verified that this is a monitor issue, as it happends when the monitor is driven by either my PC or my laptop. I also disconnected the AC input to the monitor for 2 hours, but the problem was still there when I turned it on again. 1. Can you identify the problem by the above description and suggest a solution? 2. If not, please provide me with instructions for openning the cover so that I can access the electronic boards and maybe identify bad solder or damaged part. Thanks, Dov Porat.
SOURCE: DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Posted on Aug 03, 2008
bammbammfran
  • 159 Answers
SOURCE: Viewsonic VX910 powers on, screen displays for 1 second then turns off
Blinking on and off is not always a capacitor issue, it is usually caused by faulty transistors at the high output transformers that light the backlights. Crappy board design ! But fixable in most cases.
Posted on Aug 10, 2008
  • 3 Answers
SOURCE: Viewsonic VX724 LCD Monitor
I contacted ViewSonic and they agreed to fix the problem as a warranty repair. Evidentially they're experiencing the same issue on many of these monitors. I had to pay for shipping to their Walnut, CA facility, they'll fix it and pay return shipping. Since it is considered a warranty repair, I think they should've paid for a round trip ticket. I don't want to sound like a cheapskate but it is a warranty repair and the shipping charge was $98.00. Ouch! Cheaper than a new monitor I spose, so I'm thankful for that. So those of you with this problem might consider contacting ViewSonic to see if they will repair this on a recall "like" basis if your warranty is up. If it isn't up yet, by all means send it back to them and make them fix it!
Posted on Sep 12, 2008
cashmerekay
SOURCE: Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Posted on Dec 18, 2008
MrDallasIT
  • 91 Answers
SOURCE: Power light blinking on and off
You will need to replace the below failed caps.
2 - 1000uF @ 10V
3 - 470uF @ 25V
1 - 470uF @ 10V
Posted on May 18, 2009
Display not stable
the root cause of this problem is the inverter which light up the screen.you can replace the inverter or you check for shorted transistors and replace them
Jun 23, 2013 | Computers & Internet
Tip
Chevrolet service light 1991-01
Camaro
1998-01
To reset the "OIL CHANGE" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and then goes out, the system is reset.
Corvette
1997-01
To reset the monitor after an oil change, turn the ignition on. Press the "TRIP" button so that the "OIL LIFE" percentage is displayed. Press "RESET" and hold it for two seconds. The word "RESET" should appear on the monitor, then "OIL LIFE 90%".
Impala,
Monte Carlo
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator three times within five seconds. If the CHG OIL SOON lights two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not been reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to exit programming. A chime will be heard to verify the exit.
Impala,
Caprice
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Lumina,
Monte Carlo,
Impala,
Caprice
1996-00,
1996-99,
1995-96,
1995-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. The light will flash and go out.
Corvette
1990-96
After an oil change, or when "CHANGE OIL" appears on the Trip Monitor, with the ignition on and engine off, press the "ENG MET" button (located on trip monitor) once. Press the "ENG MET" button again within 5 seconds. Within 5 seconds, press and hold the "RANGE" button (1990-1994) or "GAUGES" button (1995). The light will flash. When it stops flashing and goes out, the system is reset.
Chevrolet Suburban,
GMC Yukon XL,
Chevrolet Silverado,
GMC Trucks Sierra
2000-01,
1999-00
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Silverado, Sierra Trucks
1991-93
To reset the "CHANGE ENGINE OIL" message, turn the ignition key to the run position. Press and release the accelerator pedal three times within 5 seconds. If the light flashes for 5 seconds, the system is reset. Repeat procedure as needed.
on Dec 07, 2009 | Chevrolet Camaro Cars & Trucks
Hi there, the problem that I am experiencing with my VA712B is also a BLACK SCREEN. I turn on the computer and the picture appears fine for about ONE SECOND, then turns black and I am unable to see...
It does the same on another PC?
More likely to be caps failure in the power supply section just like the VA912 (19" version) and the rest of Viewsonic as hswon in my albums.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 24, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Is there a reset procedure for the VA712b?
Only resetting to factory default not resetting he EPROM. What is the problem with the monitor?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 19, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Low tire pressure reset selection missing from reset program
Turn ON the ignition, with the engine OFF.
Cycle the exterior lamp switch from OFF to parking lamps 3 times within 5 seconds.
Use the scan tool in order to clear the TPM DTC.
Using the RDS radio, if equipped
Adjust all tire pressures to the recommended kPa/psi. Refer to Tire Inflation Pressure Specifications in Maintenance and Lubrication, or to Tire Placard in General Information.
Turn the ignition to ACC or ON, with the engine OFF.
Turn the radio OFF.
Press and hold the DISP button until SETTINGS is displayed.
Press the SEEK up or down arrows until TIRE MON is displayed.
Press the DISP button, A chime will sound and DONE will be displayed.
Scroll until EXIT is displayed.
Press
Jan 12, 2010 | 2003 Chevrolet Monte Carlo
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
2005 reset switch oil change .
to manually reset it , turn the key to the on position with the engine off , depress the accelerator pedal 3 times slowly to the floor within 5 seconds , if change engine oil flashes for 5 seconds oil life monitor is reset ...
if the vehicle is equipped with a driver information center , reset the oil monitor by pressing driver information center SELECT button for 5 seconds while Engine Oil Life is displayed .
Jan 07, 2009 | 2005 Pontiac Grand Am
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
Desktop icons disappear when logging on
sounds like you have the display settings for power save set on short cycle.
start button on bottom left click once(leftclick)
open control panel
do to display(Windows xp) double click
go to settings
click on power settings
change to a longer time table
If you like we can do this with our screen sharing service. see my email in my profile for connecting with our team.
Feb 17, 2008 | Toshiba Satellite A105 Notebook
ViewSonic VA712B 17" Flat Panel LCD Monitor Logo
61 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
