Question about General Electric DPGT650GH Gas Dryer
Dpgt650 drum noise
At every full rotation there is a noise
    Top Expert:
  • General Master
  • 9,472 Answers
Check to see if one of the paddles in the drum are loose.
Posted on Dec 02, 2012
Dryer is growling when spinning heavy loads.
The bearings may be gone, but I don't know how old your machine is or the brand. If it is over 8 years old, consider replacing it. Maybe get an estimate from a repairman who knows your brand.
Jun 09, 2015 | Dryers
110.c68692700 need to change drum bearing
this model doesn't have a drum bearing. This unit rotates on drum support rollers which are like little wheels. You can look them up at
http://www.searspartsdirect.com/partsdirect/index.action and order from there if needed. Noise such as squealing can also come from the idler pulley assembly. You might want to replace the entire "full service" kit. That comes with support rollers, idler asmy., and drum belt.
Oct 23, 2013 | Kenmore Dryers
Dryer making a screeching noise when rotating
There are parts inside the dryer that require periodic maintenance, such as oiling the drum wheels, replacing the drum glides - when they become worn.
Sep 25, 2012 | Hotpoint Dryers
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
It makes a metal on metal noise when rotating. When I move the drum by hand the noise seems from the front and only during part of the rotation cycle.
The drum rollers or bushings are worn out.. They can be replaced. Check with a local appliance dealer
Mar 14, 2010 | Dryers
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
NOISE DRUM ROTATES
there are 2 screws holding the loewr panel on the unut, you can remove the panel and watch it operate to pinpoin the"noise" most likely cause is a roller on rear wall, or perhaps a faulty front set of glides( the drum sits onthem)
Mar 08, 2009 | Maytag SDG3606A Gas Dryer
Dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Jan 13, 2009 | Dryers
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Oct 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
General Electric DPGT650GH Gas Dryer Logo
53 people viewed this question
Top General Dryers Experts
Tim Whalen
Sal DeAngelo
Are you a General Dryer Expert? Answer questions, earn points and help others
