Question about Refrigerators
My Kemore elite refrigerator has an error message in the door...this came on after a power outage three consecutive times ..how do I clear it?
  • lormusic
    lormusic Dec 01, 2012
    Model #79577573600 Kenmore Elite Refrigerator
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the error code?
Posted on Dec 01, 2012
5 Suggested Answers
SOURCE: Kenmore Elite Trio 795.7519
This is the 1st (and easiest) step to take:
1. Turn power off to the refrigerator (i.e. unplug)
2. Leave OFF for at least two minutes to allow the CPU to reset
3. Turn power back on (plug in)
This solves 98% of these problems with the Kenmore Elites.
Step two would be to call service.
Posted on Apr 26, 2008
wheelshot
  • 102 Answers
SOURCE: a three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
Posted on Apr 01, 2009
aasc
  • 1606 Answers
SOURCE: Lights will not go out when I close Kenmore elite refrigerator
It sounds like the doors need adjusted so that when they close , the hit the light switch . Try loosening the top hinge screws , and even up the doors by the side view of the refrig . Re tighten the screws , and check to see if the lights go off . May have to try several times , to get it properly adjusted .
Posted on Oct 03, 2009
  • 699 Answers
SOURCE: We had a power outage which lasted 45min - 1 hour.
Check and clean your fridge door seals as they may be dirty, have perished/not flexible or even crack.
All doors should also close with a positive 'hermetic' feel: check and remove any obstruction.
You can check the firmness of the seal round the door with a thin piece of plastic or cardboard wedge between the seal and door 'frame'.
Hope it helps.
Posted on Sep 27, 2010
Cleaning stainsteel on Kenmore Elite
You may have to use special cleaner intended for stainless steel.
Jul 14, 2017 | Kenmore Refrigerators
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
My Kenmore Elite oven door is locked and I am getting an F93 error message. I have had repairmen here 3 times already to fix the problem. Can you help?
The F93 - Maximum oven door lock time exceeded. First thing to try is holding the clear button down for 3-5 seconds sometimes this unlocks the door and then leaves the loc light still on in this case you would open the door and once again hold down the clear to make the loc light clear. If your unit doesnt have a clear button then you would hold the stop button for the same amount of time as described above. If this doesn't work try shutting off the power at your electrical breaker for 7 minutes this usually causes the control to reset in the unit. If you have any further questions or if this does not work to allow you to be able to open the door and clear the error code message me back for further diagnosis. Thanks
Rick
Sep 03, 2011 | Ovens
My aunt has a Kenmore Elite range and it begam flashing a "PO" error message. Can you tell me what this means?
PO means power outage so if ya has a lighting storm or for some reason if the power went out thats why it says that . Push clear/off for 3 -5 seconds and codes should go out
Aug 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Either you have accidently left the door open at some time in the last few weeks or you have a faulty defrost sensor, initially turn off defrost freezer over night with doors open, turn on following day, unit should start to work within 12 to 24hrs, other wise replace defrost sensor but still deforst. Regards Advisor
Aug 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
