Question about Transcend TS-PDU3 USB 3.0 Expansion Card
I have a usb 3 expansion card - pci express interface that is not being detected by windows op7
  • Transcend Master
  • 27,725 Answers
W7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Posted on Dec 02, 2012
  • ianwebster58
    ianwebster58 Dec 03, 2012
    Thanks for that tip, but I have sorted the problem now and the card seem to be working fine. I just downloaded the software again, and windows pick up the card. I may have other problems so will keep in touch. Thanks again.
My ATI firepro V7800 makes continuous beeping noise. PC does not boot when I turn it on.....pls help!!!
1) Believe the continuous beeping you hear is a BIOS Beep Code, stating you have a graphics problem. Computer, not video card, is beeping.
2) Do you have the external 6-pin PCI-Express power cable plugged into the graphics card, from the Power Supply?
3) IF, your Power Supply does not have a 6-pin PCI-Express power cable, are you using TWO 4-pin Peripheral power cables, connected to a 6-pin PCI-Express adapter power cable?
To wit;
6-pin PCI-Express power cable example, and also showing a 6-pin PCI-Express adapter power cable on the right,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
Example of a 4-pin Peripheral power cable,
(Misnomered by many as a 'Molex' power cable. Molex was the first company to make that type of connector. The name stuck, kind of like calling an adjustable open-end wrench a Crescent wrench),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the color code of the wires used in a 4-pin Peripheral power cable, and a 6-pin PCI-Express power cable.
Red = 5 Volt wire
Yellow = 12 Volt wire
(All are DC Voltage)
Black = Ground wire. (ALL Black wires are Ground wires)
The 4-pin Peripheral power cable has ONE Yellow 12 Volt wire.
The 6-pin PCI-Express power cable has TWO Yellow 12 Volt wires.
The most power that a PCI-Express x16 expansion slot can deliver, is 75 Watts.
"This cable is used to provide extra 12 volt power to PCI Express expansion cards. PCI Express motherboard slots can provide a maximum of 75 watts."
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
"The older 6 pin version officially provides a maximum of 75 watts (although unofficially it can usually provide much more)"
The ATI FirePro V7800 graphics card requires 150 Watts by itself.
The PCI-Express x16 expansion slot CANNOT deliver the recommended power (Wattage) needed, therefore an external power cable capable of delivering 75 Watts is needed.
What happens if you just use ONE 4-pin Peripheral power cable, in a 6-pin PCI-Express adapter power cable?
The PCI-Express x16 expansion slot contact pins -> BURN
The gold plated contact pins on the bottom of the graphics card -
BURN
The connection on the graphics card for the 6-pin PCI-Express power cable - BURNS
The contact pins in the 6-pin PCI-Express adapter power cable -
BURN
If it is too bad, and cannot be remedied by cleaning, the motherboard is TOAST, and so is the graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 30, 2012 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
Does the MSI K8n NEO4 Platinum SLI motherboard support the Geforce GTX 550 Video Card?
The MSI K8N NEO 4 Platinum Edition mobo, has an AGP graphics expansion slot. (Accelerated Graphics Port)
It uses AGP graphics cards that are either 4X, or 8X. (Supports 1.5 Volt AGP graphics cards, hence 8X)
http://www.msi.com/product/mb/K8N-Neo-Platinum.html#/?div=Detail
Click on the Specification tab. Look under the bold - Slots - subheading.
(Overview, { Which is the tab it automatically opens to}, Specification, Download, Support, News and Awards, Where to Buy )
This is Evga's version of the Nvidia GeForce GTX 550,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
Click on the Details tab. (Overview, Details, Feedback)
Under the bold - Interface - heading, and to the right of the subheading - Interface, we see the interface is - PCI-Express 2.0 x16.
Tells you a lot right off the bat, if you know what you are looking at.
1) The graphics expansion slot you need on your motherboard, is a PCI-Express x16 slot.
You have an AGP graphics expansion slot. (That uses either 4X, or 8X AGP graphics cards)
2) The PCI-Express technology used is PCI-Express 2.0
Therefore the answer is No, Stephen.
[ More info on AGP graphics technology, and PCI-Express technology,
1) AGP:
http://en.wikipedia.org/wiki/AGP
2) PCI-Express:
http://en.wikipedia.org/wiki/PCI_Express
Now if someone asks you, why the GeForce GTX 550 graphics card will not work on your motherboard, you can explain why in detail, instead of just saying some dude/dudette on FixYa, said it will not work.
Are you sure some 'Mom and Pop' computer store will not trade out, a decent AGP graphics card, for the Nvidia GeForce GTX 550 you have?
Always worth a shot. Just MHO.
Regards,
joecoolvette
[ For additional questions please post in a Comment ]
May 25, 2012 | MSI : K8N NEO4 Platinum SLI/S939/nForce4...
Looking for driver for Ultra PCI Express card U12-40528.
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
http://www.driver-fix.com/scan.php?id=scan5&key=2
both of these are free driver solutions
they will automatically search for and for the correct driver
mind you it will detect all of your oudated drivers
hope it helps you
Nov 18, 2011 | Ultra Products Ultra U12-40528 SuperSpeed...
Where/how do I connect the USB 3.0 PCI Express Interface Card IFC-EC2U3/UC, Internal Power Cable? I'm about to buy one and other cards I've used for Firewire/USB 2 expansion did not require an internal...
USB 3 provides extra power though the port that firewire and USB 2 do not, as such it will need to be connected to your power supply. They should include a adapter cable to go from a molex connector to the format on your USB 3 board.
Hope that helped clear things up
Dustin
Feb 04, 2011 | Computers & Internet
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
The full details of your motherboard are below:
Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
Nov 03, 2010 | Intel D915GAV Motherboard
Wha t is a pci
Conventional PCI (part of the PCI Local Bus standard and often shortened to PCI) is a computer bus for attaching hardware devices in a computer. These devices can take either the form of an integrated circuit fitted onto the motherboard itself, called a planar device in the PCI specification, or an expansion card that fits into a slot. The name PCI is an initialism formed from Peripheral Component Interconnect. The PCI Local Bus is common in modern PCs, where it has displaced ISA and VESA Local Bus as the standard expansion bus, and it also appears in many other computer types. Despite the availability of faster interfaces such as PCI-X and PCI Express, conventional PCI remains a very common interface.
The PCI specification covers the physical size of the bus (including wire spacing), electrical characteristics, bus timing, and protocols. The specification can be purchased from the PCI Special Interest Group (PCI-SIG).
Typical PCI cards used in PCs include: network cards, sound cards, modems, extra ports such as USB or serial, TV tuner cards and disk controllers. Historically video cards were typically PCI devices, but growing bandwidth requirements soon outgrew the capabilities of PCI. PCI video cards remain available for supporting extra monitors and upgrading PCs that do not have any AGP or PCI Express slots.
Many devices traditionally provided on expansion cards are now commonly integrated onto the motherboard itself, meaning that modern PCs often have no cards fitted. However, PCI is still used for certain specialized cards, although many tasks traditionally performed by expansion cards may now be performed equally well by USB devices.
Jan 18, 2010 | Intel D845GVSR Motherboard
PCI
"As of 2007, PCI Express has replaced AGP as the most common interface for graphics cards on new systems. With a few exceptions, all graphics cards being released today (2008) from ATI and NVIDIA use PCI Express. NVIDIA uses the high bandwidth data transfer of PCIe for its newly developed Scalable Link Interface (SLI) technology, which allows two graphics cards of the same chipset and model number to be run as a pair, allowing increased performance. ATI also has developed a dual-GPU system based on PCIe called CrossFire. Towards the end of 2007, AMD released a motherboard chipset, the AMD 790FX, which supports up to four PCIe x16 slots, allowing tri-GPU and quad-GPU configurations for ATI cards.
Uptake for other forms of PC expansion has been much slower and PCI remains dominant. PCI Express is commonly used for onboard gigabit ethernet and wi-fi but add-in cards are still generally PCI, particularly at the lower end of the market. Sound cards, modems, serial port cards and other cards with low-speed interfaces are still nearly all PCI. For this reason most motherboards supporting PCI Express offer legacy PCI slots as well."
Source/Link: WikiPedia
Please let me know if this helps. Good luck!
Feb 28, 2008 | Televison & Video
Transcend TS-PDU3 USB 3.0 Expansion Card Logo
392 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
