Question about Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A
Rinnai Silent Servant 606A thermostat is located where? My heater stays on too long...i can't get it to register room temp accurately. Thanks!
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
Posted on Nov 26, 2007
  • 53 Answers
SOURCE: I have a Rinnai 506 silent servant vent free
yes you can, but is complicated, involves changing injector, burner, and reprogramming the PCB for the new gas type. Get a pro to do it for you
Posted on Dec 05, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: room temp and unit temp are way different what can
The Rinnai's temperature probe is located very low (about 2" off the floor} and is telling you what temperature the floor is. There are two things you can do. Remove the front cover and look for a yellow wire wrapped up with a black plastic tie. Remove it from the tie and feed out some extra wire to the back of the heater. Next take off the right side trim panel closest to the wall. You will find a yellow wire with a black rubber tip clipped into a black plastic holder. Un-secure the probe and relocate it higher up in the back of the heater. Do not place it near the cloth and metal vent pipe. It is OK to place it near the corrugated gray plastic pipe. This will give the probe a better sample of the room air. The second way is to insulate the wall behind the heater so that the probe will not be effected by cold air infiltrating from the wall. If this does not help the situation, replace the probe called a thermistor. I can send you one for $25.00 if you find you need one. Contact me at the_rinnai-guy@hotmail.com.
Posted on Dec 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: have a 1004fa model to heat a room. temp on
You may have a bad circuit board. Depending upon the age of the heater it may still be under warranty. Contact Rinnai (in US) 800-621-9419 with your serial number and installation date. Ask if they can offer a solution. Good Luck!
Posted on Jan 13, 2010
  • 120 Answers
SOURCE: Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Posted on Jul 30, 2010
Rinnai 606a manuel
Rinnai 606a manuel Google Search ..goto this link and see if you find your manual
Dec 02, 2016 | Rinnai Heating & Cooling
My 606a rinnai heater flashes 12
According to the Rinnai manual which is here:
https://www.rinnai.us/documentation/downloads/RC-606-48x05(00)_owners_manual_RCE-606TRAII_vent_free.pdf
It looks like that is a "flame failure". They suggest ventilating the room and turning the heater off and on again, I think this might mean the heater was eating all of the oxygen in your room.
Maybe cracking a window a small bit?
Problem is with my Rinnai propane gas heater in my LIVING ROOM, not car. Please see previous question. Thanks.
Turn it off. Check connections and hoses with very soapy water for leaks (it will bubble)
If you can't find it... I would either return it if possible... or go take it to a propane professional for testing.
Dec 20, 2012 | Rinnai Energy Saver Direct Vent Wall...
Rinnai Avenger 25...Thermostat is on 26 but the room is no where near that hot??
the heater will attempt to heat the room until temp is reached if door is opened or cool air enters the heater will continue to run if the heater is set to 20 when the room reaches 20 the heater will shut down until temp drops below 20 then restart
Jun 12, 2011 | Rinnai Heating & Cooling
Mar 13, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Have a 1004fa model to heat a room. temp on
Jan 13, 2010 | Rinnai Heating & Cooling
I have a Rinnai 506 silent servant vent free propane heater, can I switch it for use with Natural Gas?
Nov 30, 2009 | Rinnai Vent Free Gas Heater/
Temperture bulb
A temp bulb will is only accurate to plus or minus 10 degrees sometimes as much a 20 degrees the ideal place for the bulb is in the intake air flow the bulb comes with a line that is long enough for this application
Oct 07, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai 1004 heats to a temp 4 degrees higher than set temp, adjustment?
You can adjust the position of the room air sensor found on the back of the unit between the heater and the wall. It is a black rubber bulb with yellow wires. There is a few inches of extra wire you can extend higher to get a more accurate reading of room air. While you are back there, check for drafts that will give you false readings.
Sep 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Nov 24, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Open Questions:
See all Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions
Heating & Cooling Logo
105 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
