Question about Kenmore Sewing Machines
Kenmore 1560 feed dog will not work
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
SOURCE: bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Posted on Jul 13, 2008
  • 19 Answers
SOURCE: My kenmore 385 won't feed fabric
hi there check feed dogs are up not down mary h
e
Posted on Dec 30, 2008
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
  • 323 Answers
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
Posted on May 16, 2009
Kenmore Sewing machine model 385.1884180, feed dog quit pulling
A common malady with Kenmore sewing machines. The feed system needs lubrication and perhaps some solvent cleaning to loosen sticky pivot points. If you are adventurous, you could take off the bottom and oil all the moving parts. Or take it to a service person.
Jun 12, 2009 | Kenmore Sewing Machines
sewman7
May 14, 2009 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
e
Dec 28, 2008 | Kenmore 16622 Mechanical Sewing Machine
Feed dogs not feeding material
Make sure that you did not disengage the feed dogs by accident. You should have some type of button that allows you to control the feed dogs.
Dec 26, 2008 | Kenmore Sewing Machines
Sep 20, 2008 | Sewing Machines
Feed Dogs Kenmore 158.19802
I think the feed dog lever needs to be positioned on the right.
Sep 15, 2008 | Sewing Machines
Feed dog
There is a black lever behind, above and to the right of the needle.
Aug 24, 2008 | Kenmore Sewing Machines
Kenmore 19153
Sounds like you need a new needle and the upper tension tightened. Try putting machine oil on the feed dogs and working it up and down until it is free again. You can take off the lower plate and clean any lint that may have collected underneath. Then make sure the thread is coming out of the bobbin correctly before it is inserted in the machine.
Zelma
Jan 18, 2008 | Kenmore 19233 Computerized Sewing Machine
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
