Question about Compaq Mini 110c-1001NR Notebook
New battery won't charge
  • Compaq Master
  • 7,627 Answers
Some inexpensive batteries do not play well with your laptop. Take a look at "Plugged in, not charging" SOLUTION!!!" :http://forums.cnet.com/7723-19681_102-345945/plugged-in-not-charging/
Posted on Dec 02, 2012
Despite of new battery my Asus PRO50 won't charge a 100%
Is it a replacement battery? Are the specs the EXACT match, DC volts and Amps? Some inexpensive batteries do not work well with your laptop, it's a Connector/ pin thing, they don't communicate with the laptop. Try pulling the plug and drain the battery and recharge. Cycle it a 4 times, drain/ recharge. Does your BIOS setup have a Battery Learning section?
Dec 13, 2012 | ASUS Computers & Internet
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
2001 ford taurus power draining new battery & new alternater won't work when cables are removed from battery
That suggests that the problem is in the harness, something in the connector or wiring is causing an open circuit. You will need to have the circuit tested to find the fault. Ford alternators have known connector issues & new aftermarket connectors are readily available at most auto parts stores.
Oct 25, 2017 | 2001 Ford Taurus
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
New battery carwon't start
Make sure battery terminals are clean & tight.Also make sure polarity is correct & battery is fully charged.Thats a good start
Dec 30, 2011 | 1998 Saturn SL
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 10, 2011 | Computers & Internet
Two new alternators on and the car still will not charge and it kills alternator. Need to know what to look for in the wiring harness. Auto Zone tested alternators before installation. Still won't...
Go to web site WWW.HMASERVICE.COM and register your vehicle by VIN #. You'll then have access to shop manuals, wiring diagrams, technical service bulletins, illustrations, etc.
Provided there is no problem with the vehicle's wiring, find out what the charging current is to the battery. I've seen batteries which TEST good, but when under a CHARGE short out internally.
Example: Tested a battery & charging system on a Hyundai Elantra, the battery tested "Healthy" but indicated there was a CHARGING SYSTEM PROBLEM. I checked the battery voltage while the engine was running and found the battery voltage at 14.3 VDC (which was normal). I then used a Digital DC Clamp meter arount the positive (+) battery cable & found the battery was charging at 70 Amps!.. it was supposidly already fully charged (should have only been taking 4 to 6 amps when fully charged).
Best guess without looking/diagnosing the vehicle myself
Maybe this will help.
Jun 30, 2011 | Hyundai Elantra Cars & Trucks
Compaq Mini 110c-1001NR Notebook Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
