Question about LG DU-42PX12XC 42 in. Plasma HDTV
BLUE VERTICAL LINE
A 1" blue vertical line from top to bottom appeared about 5" from the right side of my plasma screen tv. It's on the screen most of the time and only disappears for a few minutes then it comes on again. How do I fix this? Help please!
  • 4 more comments
  • kev111 Nov 14, 2007
    Same problem as Bend it only my blue line has become permanent.
  • mongoose5150 Nov 17, 2007
    I have many 20 LG plasmas of this model. I have had this problem appear on 5 of those 20 plasmas. I sent one to a shop and was told that it had a bad panel. I find it hard to believe this is a panel issue when it is happening on a 25% of my TV's. (sports Lounge)
  • jakp Jan 03, 2008
    I have heard several people with the same problem recently. O f course, just a few months after the original 2 yr warranty expired from pruchase in spring 2005. In, fact, literally dozens in the same San Elijo Hills, Old Creek Ranch , Dove Vally Development/neighborhood. The builder bought and installed through Centex Homes, now dozens with the "blue vertical line"
  • MattPlay Jan 10, 2008
    My LG plasma has also developed this vertical blue line,about 1-2" thick and about 5" from the right side of the screen. It suddenly appeared and went away for a little bit then reappeared and has not gone away since. Rebooting it several times, disconnecting and reconnecting cables, and changing inputs/channels does not help.
  • Anonymous Mar 15, 2014
    one black vertical band, few pixels wide , about 1 inch from left side of screen
  • Anonymous Mar 19, 2014
    When i turned the tv on the above problems used to disappear after the tv was on for a while and the tv went to normal condition, but aterward it stayed the same and did not clear up as mentioned above.
I have the same problem--two months out of warrant of course--any one have any luck getting their's fixed?
Posted on Dec 17, 2007
I have the same problem with a vizio plasma 42 inch. i just want to know more information about the modules.
Posted on Dec 16, 2007
    President:
  • 1,284 Answers
The address module that is at the bottom of the PDP in that location is the suspect and the cheapest repair. There is usually 3 to 4 modules at the bottom of the PDP and each one addresses information vertically. If it were just one pixe wide then the PDP would be bad.
Posted on Jun 08, 2007
A group of 16 vertical black lines have appeared
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Mar 26, 2010 | LG MZ-42PZ14 42 in. Plasma Television
42 sony wega plama veritcal line
The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
Beware,the flatcables wich the resistors are located on are verry fragile!
Nov 02, 2009 | Sony WEGA KZ-42TS1 42 in. Plasma...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
LG DU-42PX12XC 42 in. Plasma HDTV Logo
479 people viewed this question
Computer Repairing
Computer Repairing
