Question about Westinghouse SK-26H590D Television
Westinghouse 32" led service menue access codes
2 Suggested Answers
gopakumarg43
  • 75157 Answers
SOURCE: fios remote code for Westinghouse LED 32
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Posted on May 29, 2012
I need a channel access code for a Westinghouse model VR5535Z
try this...
Contact westinghouse Channel Access Service by:
web: www.westinghousedigital.com/support;
select Channel Access and enter Access info.
Text Message: Text Tuner to 95495
Phone:1-800-701-0680 follow instructions
Jan 22, 2018 | Westinghouse Televison & Video
Where is led driver located on Westinghouse DW39F1Y1
I don't have a service manual for your set but I believe the LED driver is part of the power board, did you test the voltage going to the LED panel?
Nov 16, 2017 | Westinghouse Televison & Video
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
How do i get cable tv on my westinghouse tv
Go to the menu look for the input settings make sure it is set for cable not air. There might be a input button on the side of tv or on remote that will let you select which input to use. It will have to be set on cable thin scan for channels.
Aug 08, 2017 | Westinghouse 32-inch Led-lcd Tv - 720p...
How to enter service menu on my Apex Digital Apex 32 in. LED 720p 60Hz HDTV LE3242
Not meant for access by the owner. It helps service technicians while repairing your TV. Messing around there can seriously wreak havoc on the normal operation of the TV.
Jul 05, 2015 | Apex Digital Apex 32 in. LED 720p 60Hz...
Picture cannot be made to cover full screen. how do I fix that?
check in main menu or setup for aspect . perhaps you need to set it to a lower number .
Mar 22, 2015 | Westinghouse 32-inch Led-lcd Tv - 720p...
Westinghouse codes
I just bought a 40" Westinghouse at BestBuy and had the same problem. My TWC remote still had the code from my old analog Samsung. Fortunately I kept the code sheet from Time Warner and using the 3 digit method reprogrammed it. Westinghouse uses 4 dif codes on their LED-LCDs. Here are the 3 digit code nos. 076 276 435 001. I ran thru the first 3 and mine was 001. Whoever your provider is use their remote to do this and not the one that came with your set. I used that remote to make all the adjustments on my set to fine tune it, color, sound, etc.following the menu. Hope this helps.
Aug 18, 2014 | Westinghouse Electric LD-3255VX 32 in. TV
Fios remote code for Westinghouse LED 32
May 28, 2012 | Westinghouse 46? 1080p Led Tv ld4680 /...
My Westinghouse LD-325 series LED TV will not shut off/on with the side button but it will respond to the remote OR by pressing the top two button at the same time. By pressing the top two buttons (m
one or more of the tiny switches on that board with the controls is bad--either replace the board with the controls or just use the remote.
The plastic buttons will seem fine--it is the tiny switches under them that causes this issue.
May 03, 2012 | Westinghouse 32-inch Led-lcd Tv - 720p...
I have a 32 inch Westinghouse LED slim tv. I try to put a attena and it ask me for a 5 digit access code . I have no idea what's the code. Can you help me.
You have to go to http://wdsupport.net/wdeonlineservice/tunercode.aspx to get the access code to unlock the ATSC tuner. Find your TV model in the list on the right then enter the serial number in the box. The code should appear below that. You can also request a copy of the access code by email. If you have any problems, call the Westinghouse customer service line, 1-800-701-0680, during weekday business hours.
I hope this helps.
Apr 13, 2012 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
