Question about Home
Why is whirlpool bath jet sucking in water instead of out?
Just replaced pump and all the jets are sending water out but one is sucking water in.
blueextc3221
  • 15935 Answers
SOURCE: whirlpool bath jets
open the side panel and there will be a sticker on or near the pump with all the info
Posted on Dec 23, 2008
PartsCenter
  • 125 Answers
SOURCE: my whirlpool bath tub has three jets that work & 3 jets that are
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
Posted on Feb 24, 2009
  • 80 Answers
SOURCE: I know I can take a bath without turning on the
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Posted on Aug 28, 2009
  • 80 Answers
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Posted on Sep 28, 2009
  • 258 Answers
SOURCE: Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Posted on Feb 15, 2010
Kohler whirlpool type tub will not pump water out of its jets or take water into the intake. Pump appears to operate fine. Water does not want to move. Suggestions?
When a bath pump turns on but does not move any water it is usually because there is an Air Lock and needs to be released.Try this.
  • Fill the tub with water
  • Turn the pump on
  • Unthread the discharge pump union until water starts to squirt out
  • when this happens you should hear a big 'swoosh'
if the bath pump starts to discharge water through the jets then you have solved the problem.
Rod
us parts center
888-521-6183
Apr 05, 2013 | Kohler Home
How to start the jets on an MTI FURO MTDS 59
Checking the circuit breaker for power to the pump is obvious however the control that turns the bath pump on/off may be the real problem.
MTI has what control box to operate the pump?
Check there first because that may be the problem before the bath pump is a problem.
We would need to know the model number of the bath pump and the control box if there is one that the bath pump plugs into.
Rod
US Parts Center
888-521-6183
Mar 11, 2013 | MTI Furo MTDS-59 AST59
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Feb 22, 2013 | Home
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Whirlpool bath jets
Dec 23, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
My whirlpool bath tub has three jets that work & 3 jets that are
Nov 19, 2008 | Home
Home Logo
168 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
