Question about Onkyo TX-DS989 Receiver
Receiver not taking commands from the remote
I'm currently having problems using my remote on the receiver. The remote had programmed functions on it, for example the tv. The remote works on the tv, but when i change the remote to AUDIO and try to use it on the receiver it doesnt work. I've tried everything on the manual troubleshooting. I've also tried erasing all the programmed functions. All the function on the Receiver works properly, it just doesn't work on the remote. Thank You
    New Friend:
Wondering if you were able to fix this problem? I have the same issue
Posted on Mar 14, 2013
    President:
  • 3,130 Answers
Point the remote at a digital video camera to see if you can see the small blue infared light comming from the end of the remote when you aim it at the camera and press a button. if you do see the light then your receiver has a system control problem I'm afraid. You see your eyes cannot see the infared light but the camera optics can. Good Luck
Posted on Jun 07, 2007
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    I have a jvc LT42P510 tv and it is hooked up to a Dish Network 722k hi-def dvr receiver, the dish remote will not function in the dish mode, for example when the dish receiver is plugged into the tv using...
    hi,
    Check the version of the hdmi cable you used. Try to use hdmi cable version 1.3 or above . Also try hdmi cable with version 1.2 .Version of the cable is very important one.
    ok
    Mar 04, 2011 | JVC LT42P510 42 in LCD TV
    Harmony remote control - volume won't stop increasing when the button is pushed
    First I would check if the remote is momentarily sending out the volume command or is it sending it out continuously. You can use this trick with any IR remote. Using a digital camera with display, point the remote at the camera and press the volume button on the remote. If the IR led is working then you should see it glow on the cameras screen. When you release the volume up button, the IR led should stop glowing. If it does not stop then you may have a sticky key or a problem with the program. If it shuts off then the Harmony is functioning ok and there is a problem with your receiver. Another way to test this is to press the volume up button and then immediately cover the remote with a blanket or take it to another room or remove the batteries. Let me know if the remote is continuously sending out the Volume command or is it momentary.
    Hope this helps.
    May 02, 2010 | Logitech Harmony One Advanced Universal...
    Program remote to replace all remotes
    Hi, yes of course it is possible! First off, you have to make sure that your Dish device it set on remote address 1 in order for it to be controlled by the Harmony. Then, once you add the device to your Harmony account, if there are any functions that are missing, you can learn them right from the original remote .
    Adding a device:
    1. In the software, clcik 'Add Device'
    2. Follow the on screen instructions.
    Learning a command:
    1. In the software, click 'Learn IR' next to the icon for your Dish device.
    2. Go down to the bottom of the page where it says 'Learn a new command'
    3. Type in a name for your command, and click 'Learn'
    4. Follow the on-screen instructions.
    Hope that helps you get this set up right!
    Mar 17, 2010 | Logitech Harmony 700 LCD Remote Control
    LG42PC3D TV - No remote control. Manual control works.
    dont blame the receiver yet, the problem mostly comes from the remote control. it may be the infrared emiting problem. checkout if the infrared in the remote control is emited well. to see this infrared you can read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
    good luck
    Dec 05, 2009 | LG 42PC3D 42 in. Plasma Television
    We have just inherited a Yamaha RV-X592 Audio Receiver and have tried all the remote codes listed with the universal remote that we purchased. I have found two listed codes that turn the reciver off, but...
    You need a learning remote or a "Logitech Harmony" or a "Universal Remote Control" (Brand name) Yamaha uses "Discrete Power Commands"
    You will not find those in any remote under $70 or $80.00
    If you don't want to spend the money, program the Yamaha's Remote to control your devices. It will control all features and functions, it will just take some time to program. Hope this helps
    Sep 26, 2009 | Yamaha RX-V592 5.1 Channels Receiver
    Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
    Your using a universal remote from what U am understanding, Two solutions for ya
    1)diffrent remote all togeather from radioshack
    or
    2) the Tv's IR is not working
    Apr 22, 2009 | Panasonic CT-27SL14 27" TV
    Yamaha RX-V663 delays 10-30 seconds between commands using the remote control. New batteries, new receive. For example, try to raise volume. It goes up 1 dB then cannot give any other commands using the...
    I have seen this type of thing with several remotes.  You have some light source in the room that is interfering with the reception of the ir.  Turn off all light sources in the room and then try.  You might be surprised!
    Dec 20, 2008 | Yamaha RX-V663 Receiver
    Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
    Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
    If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
    If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
    Oct 30, 2008 | Logitech Harmony 880 LCD Remote Control
    Sony STR-VX550 receiver does not respond correctly to commands from optional Sony RM-S750 remote commander. Remote is working properly and activats all functions on my other STR-VX550. Only on/off command...
    If this is a recent occurrence, unplug receiver for 20 minutes. This will reset the receiver. If the remote is programmable, reprogram it for the receiver. If you do these steps and it does not work, you need a different remote.
    Aug 22, 2008 | Sony Audio Players & Recorders
    Onkyo TX-DS989 Receiver Logo
    230 people viewed this question
    Top Onkyo Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
