Question about Harman Kardon GLA55 2 Speakers
I have a big repetitive cracking noise produced by the totally new Harman Kardon GLA55 2 Speakers
The noise is coming event when no Jack is inserted in the speakers
  • isgetz Dec 03, 2012
    perhaps it's related to the fact that I'm using a Power line communication (PLC) adaptor plugged in my electricity circuit
Open SKy
  • 618 Answers
SOURCE: harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Posted on Dec 30, 2007
SOURCE: Speakers Make a Very Loud Noise that Increases
speaker amplifier chip may leaky or damage
you are using improper sound driver
check driver status in your computer device manager or just typing dxdiag on run in start menu, check status of sound driver installation
Posted on Jan 17, 2008
whitebirch
  • 433 Answers
SOURCE: i need connection instructions, please
http://www.harmankardon.com/product_support/SupportDetails.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=HK695&sjump=ps&ky=295752998DFB844994AFB5150B637833&#active
Here is the info you need to connect, manuals, troubleshooting, drivers...And instructions.
Please leave rating
Posted on May 03, 2009
SOURCE: I need to replace an AC transformer for harman kardon PC speakers
If you still need it, I have the Hon-Kwang Plug in Class 2 Transformer Model A15-110.
Posted on Jul 12, 2009
billfox1966
  • 231 Answers
SOURCE: removing cover from speaker
pull off the cloth cover by using your nail or a screwdriver to get behind it. its simply a push fit cover.then you can acess the screws. there are 4 deep in the holes where the cloth covers connected to the speaker and there are 4 holding the actual speaker to the face that are plainly visible once cloth front cover is removed.
Posted on Jul 24, 2009
Why doesn't subwoofer work?
Your nose and eyes should lead you to the faulty part for this, once you get inside the subwoofer. Anything that burns up producing the smell will possibly leave a visual trace. But your nose will lead to the part that smells. Replace it and see what happens!
Nov 26, 2015 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Harman/Kardon speakers hooked to my computer
Make sure that you have connected the jack to the right port and the mute is off
Oct 12, 2008 | Harman Kardon Audio Players & Recorders
Harman Kardon speaker jack broken. What to do
if you know how to solder you can just remove the jack and replace it with another one, of course you can ask someone else to do it at a nearby electronics store
Dec 12, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Will Harman Kardon HK 206 speakers work with Dell Inspiration 560 with Windows 7 and if so how do you hook them up and install
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
Jun 27, 2011 | Harman Kardon HK206 Computer Speakers
Problem with stereo output on Edirol FA-66
Possibly, your adapter of small to big is not a stereo adapter. Seems like a mono adapter.
Jun 15, 2009 | Edirol FA-66 Sound Card
Harman Kardon DPR 1005 problems
Sounds like the power supply or associated module. Definitely fixable, but probably needs a technician.
May 13, 2009 | Harman Kardon DPR 1005 Receiver
No Sound from speakers
Is everything in this equation new and never worked right? That opens up endless possibilities for what the problem might be, but improper setup is most likely.
Assuming you have one of the variants of Windows:
Try going into the Control Panel.
Find the icon for Sounds and Audio Devices, under the Volume Tab see if Mute is checked. UNcheck it.
Also look at the Device Volume slider to make sure the volume isn't all the way down. I leave mine on HIGH.
The Sounds Tab allows you to assign sounds to certain events, like email notifications.
Jan 21, 2009 | Harman Kardon HK695 Computer Speakers
Garbled sound
Your Codec is damaged. Reload your drivers for your sound card. First uninstall the old ones. Moving your non working speakers and they play fine says they are good. I have a problem that you have new speakers and the problem went away. Drivers do not care what speakers are on the other end. It only produces output. Now that your second pair is working correctly, put back the Harmons and see if the problem comes back
Mike
Apr 23, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon GLA55 2 Speakers Logo
22 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
