System restore has stopped working on my hp g-61 wm511 laptop
When i try to do a system restore i get that it had an error while trying to run.
  • 7,627 Answers
Unplug, remove battery, leave battery out, plug in . repeat system restore. What is the error? Perhaps a system recovery?
Posted on Dec 02, 2012
  • Karen Whitesell
    Karen Whitesell Dec 02, 2012
    System restore did not complete successfully. Your computer files and settings were not changed. System restore failed to extract the original copy of the directory from the restore point. Source: %System Root %\Registration. Destination: ComPlus Staging. I tried taking the battary out and running System Restore and this is the error message.
  • max carson
    max carson Dec 03, 2012
    Obviously your restore is corrupt. Do you have repair disk? I don't know your OS? I suppost a last resort is a full system reload. This forum may help :http://answers.microsoft.com/en-us/windo...
Pyrhyc
  • 2028 Answers
SOURCE: laptop keyboard not working
Random keys or a row of keys not working indicates that the keyboard is failing and needs replacing. Before replacing, you might try taking the keyboard off and cleaning the connection. A little dirt or corrosion built up might cause this, but most likely the keyboard has malfunctioned.
Posted on Jul 23, 2008
  • 17 Answers
SOURCE: system restore disk for HP compaq Presario 1700 help
hi, you may need to set your laptop to boot from the cd/dvd. you will need to enter the bios and check the boot priority. power the laptop as soon as you power on press either F2 or F10 to enter the bios (you have to be pretty quick with the F2 button). once in the bios look for the heading BOOT or BOOT PRIORITY F5 or F6 willchange the boot order.
hope this helps
Posted on Feb 22, 2009
zohail
  • 1223 Answers
SOURCE: Error message eNM Tray stopped working
actually this is normally because of spyware and adware installed in system or some infection due to virus the OS is corrupt , u cant repair it except u have to restore ur system thru backup disc or the procedure below is recommended
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
ur system will be restored to factory default state and ur all problems will be gone pls first backup ur data in case it is wiped off by the restore process
it is good to keep ur system updated thru widows update and latest drivers and utils thru acer support
ftp://ftp.support.acer-euro.com/notebook/aspire_5610/
pls rate me fixya if i have fixed ur problem
Posted on Mar 03, 2009
pankaj_dic
  • 1250 Answers
SOURCE: My HP Pavilion dv6000's sound system is not working. Stuck mute
go to device manager remove the drivers then reboot your system then install the drivers, then check,
Posted on May 31, 2009
  • 7 Answers
This is a common problem, the cable that connects the button board to the system board goes bad. Usually but not always the power button stops working as well and the speakers. Replacement cables can be purchased on eBay or from: www.2fix.net. Its fairly easy to replace the cables.
Posted on Aug 18, 2009
Hp compaq laptop how to restore to factory default?
Go to Start/All Programs/HP Tools/HP PC System Recovery
If this doesn't work then try pressing the F10 key multiple times during the bootup to access the recovery console.
If this still doesn't get things fixed then you need to re-install XP
If this answer helped you then do visit my blog TECHAMY
Jul 09, 2012 | HP Computers & Internet
Hey, my HP webcam stopped working a few days ago and I've not been able to get it to work on any chat sites since then. I go to select it and it isn't there, almost as if it isn't installed. Help please?
  1. If you can, unplug the webcam and plug it back in. If not, restart your computer and try accessing your webcam again.
  2. If this doesn't work, you will need to uninstall your webcam drivers/software, and then reinstall the drivers/software.
Feb 18, 2011 | HP Computers & Internet
On statr up I get a dialogue box that reads system32/cmd.exe/startnet.exe and it jus keeps repeating this
system 32 contains a number of the system files that Windows needs to use in order to be able to run. right click on the drive in which you have installed windows and try doing a disk clean up and an auto matically fix filesystem errors and scan and attempt recovery of bad sectors.if this doesn't work try restoring the system to an earlier restore point.this should solve the issue in 90% cases
Dec 31, 2010 | HP Compaq Presario CQ50-110US Laptop
HP Pavilion DV6812 is not recovering or restoring!!
If you mean this errors
STOP 0x0000001a (0x00041284, 0xca9a2000, 0x000077e0, 0xc0c00000) MEMORY_MANAGEMENT
STOP 0x0000004e (0x00000007, 0x00007abf, 0x0000f17e, 0x00000000) PFN_LIST_CORRUPT
STOP 0x0000000a (0x00000028, 0x00000002, 0x00000000, 0x8012d2d6) IRQL_NOT_LESS_OR_EQUAL
STOP 0x00000050 (0xc2332b94, 0x00000000, 0x00000000, 0x00000000) PAGE_FAULT_IN_NONPAGED_AREA
Its ram problem,so first if you can access the bios check if your ram are been recognized and load default bios settings.If are OK in bios remove RAM and reinstall again.If the problem still exists try again testing your Ram with the Microsoft program or with that.
If the programs founds an error you RAM are damaged and replace them.
Feb 04, 2010 | HP Pavilion dv6812nr Notebook
The sound on my HP notebook just stopped. The
1st open your volume control and make sure it is not muted as this is a common error. If not then check the device manager and make sure there are not errors on you audio device. Try updating or reinstalling the drivers for you particular model which can be downloded from HP's site.
If all else fails try a system restore and go back to the day you know for sure that your sound was working properly.
Nov 06, 2009 | Gateway M305CRV Notebook
Keyboard on hp dv7-1130us stopped working
This sounds alot like a virus i once had!
try a system restore to the point before these problems occured. if that doesnt work run a full virus scan. If that doesnt fix the problem you may have to wipe the hard drive completly.
Apr 26, 2009 | HP Pavilion dv7-1130us laptop
NO SOUND ON MY TOSHIBA LAPTOP
You can try a system restore, ie you can take back your computer to a date when it was working fine .
Running system restore in windows Xp:
Start >All Programs> Accessories >System Tools >System restore
Running system restore in Vista
Start> write "system restore in start search bar "> click system restore
If the system restore doesnot work , try uinstalling the sound drivers from the add remove programs and install the new ones from the link below
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-A25-S207/download/page,sh,30994,221,19,.html
Thanks
proton
Jan 10, 2009 | Toshiba Satellite A25-S207 Notebook
Hp Laptop
Try system restore. I would use the restore disks instead of retoring off the hdd
Dec 28, 2008 | HP Pavilion dv9000z Notebook
Sound problem
Have you tried to do a system restore for before you started having this problem? You should be able to find system restore in the control panel under performance and maintenance. Let me know if you need any more help.
Nov 10, 2008 | HP Pavilion dv6000t Notebook
Usb ports not working
hi,
What device are you trying to connect? was there an error message when you plug in the usb device. try booting up your computer to safe mode with networking.
1. Restart the computer
2. Keep on tapping F8 when you have the HP logo screen, using the down/up arrow of the keyboard choose safe mode with networking. if the device still not working then it could be a problem with the USB driver. You may try restoring your computer back to the working time using system restore. Just go to start then Accessories - System tools- system restore.Restore your computer to a working date.
Keep me posted.
Thanks.
Nov 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
