Question about Philips Magnavox 20MS233S 20" TV
Magnavox, channel buttons cycle through sources
Whenever i hit the channel up or down buttons it cycles through the source modes, ( av1, av2, hdtv, pc. etc) same thing happens on both the remote and buttons on the tv as well. How do i change this?
  • 8,596 Answers
You need to reprogram your TV if you do not have a cable box or satellite box, otherwise those are going to be the only channels that the unit will pick up. If you do have a cable box or satellite box, just hit 0-3 or 0-4 if you are using a coaxial wire. If no box is present, you can just go into the menu and hit autoprogram - select cable for direct cable from wall, and antenna for antenna. Note: this particular TV is going to need a box in another 5 weeks due to the DTV transition, so my solution will only carry you for another few weeks.
-Tha Mp3 Doctor
Posted on Jan 11, 2009
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
Sanyo tv change to av1 av2
Whenever your change from one video source to another, your tv automatically switches input modes (i.e. av1 to av2) to faciliate the source coming into your tv.
Aug 10, 2014 | Sanyo DS32920 32" TV
Where can i buy a new remote mine got water damaged
It depends on the TV (make/model). Do you have an Input or Source button on the TV? Then you can use that button to change your input. A few models will offer an alternative option to change the source from the menu and have a Menu button on the TV. (Some TVs only let you change the source from the remote.)
Some remotes are available from the manufacturer's parts store (Sony, for example). remotes.com has the exact original or a replacement remote for many brands. For other TVs, a universal remote may work. Look for a higher end universal remote with a Source or Input button. Then test all of the codes for your TV brand. (Some codes may only enable parts of the remote functions; make sure you find a code that lets this button work.) The remotes that can be programmed with a USB connection to a computer are the easiest to set up for this situation.
Please add a comment with the specific make and model of your TV; I'll try to find a source for an exact replacement remote.
(some really old TVs let you swap from AV1 to AV2 to channels by going up or down through all channels to reach a point where you could swap the inputs.)
Feb 03, 2012 | byD sign Televison & Video
I have just got a cctv camera it only shows up on av2 however i can't record that channel i can only record av1, its driving me crazy!!!
Some VCRs have the ability to switch the output/input of AV2 so you can record it. Look for the AV1 or AV2 on the menu of the VCR for recording options.
Otherwise get one of these Scart boxes which you can find on Amazon. The buttons allow you to record and switch sources. They are not expensive.
Oct 28, 2011 | LG MG64 VHS VCR
How do I switch to AV3 , AV2 And AV1 functionon the sony Bravia 40 inch HDTV
All you need to do is press the TV/VIDEO button in the top left corner of your remote. Each time you press, it will cycle through the connected external inputs, e.g. AV1, AV2, etc.
Hope this helps.
BElectric
Nov 23, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
We turn it on and the screen stays blue...it is connected to the cable but won't get a picture nor does the original set up come on
I don't have the manual in front of me but what you need to do is change the source. The tv accepts input from various sources and connections. So you need to tell it where to find the signal you want. On your remote there will either be a button marked source or you will have to find it from the setup or menu button.
Usually there are 3 or 4 valid inputs. So all you do is press the source button and it switches to the next source. If there is nothing there you press it again and it goes to the next and so on. It will just keep cycling through the inputs as you press the button. You should see something marked as AV1 AV2 CABLE as you cycle through. When it finds the cable source it will then scan through and mark the avilable channels. This may take a few minutes. After that you can just use the remote to normally switch channels up/dwn etc.
May 09, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do u turn to scart channel without a remote
Not knowing what model of TV you have, the most common ways are either by using the Source button then scroll to AV1 input or if you have a Menu button there may be a sub-menu for Input, again select AV1 (depending on which AV connector you are linked you maight have to select AV2). If you have a DVD or VCR connected to the AV source, then when pressing play the DVD/Tape should automatically switch over to AV.
Jul 08, 2009 | Televison & Video
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
Magnavox 42 inch LCD TV
I was having the same problem. On my tv it was caused by a loose or faulty interface chip. I solved this on my television by opening the case and unplugging the circuit board at the top center where the menu and channel buttons are located. I've been running the tv for about a week and have had no more problems.
Jan 06, 2008 | Televison & Video
Philips Magnavox 20MS233S 20" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
