Question about Pride Go Go Elite Traveller Plus 3 Wheel Travel Scooter
8 Beeps motor is disconnected
Battery shows full charge, had it disassembled in storage and am taking it out for a needy friend to have. Don't know where to start in fixing this for them.
  • Pride Master
  • 1,271 Answers
Firstly check the connection to the rear axle, that is where the frame come apart from the axle, or is it using plug connector , what ever make sure the connections are clean and touching.
Regards
Posted on Dec 11, 2012
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
Motor turns but able to stop chuck with my hand
Battery is weak or no longer capable of taking a full charge to activate drill with full power
Jan 28, 2016 | Drills
Please robin - try to understand - you tell me that the beeper is attached to the cable - i don't know where the cable is - don't tell me its by the controller - i don't know what the controller is or
the beeps are diagnostic beep codes and the sounder should not be disconnected,
count the number of beeps then refer to my chart.will tell you what problem is
2 battery voltage too low =fully charge min 8 hours
3 volts too high =contact dealer
5 scooter in freewheel or Brake trip=chech in drive then turn on
6 throttle wig wag faulty or not in center when turning key
7 throttle or speed pot wireing or faulty
8 motor faulty or wireing poor /disconnected
9 battery pack pads and terminals coroded .replace them £2 eachn from pride or controller faulty ..replace
Advisory the analog battery guages on these regulary go faulty and read over full get electrical friend to check battery volts 12.8 to 13volt =fully charged
Dec 29, 2014 | Pride Go-Go Sport 4-Wheel
What is the power storage switch supposed to do?
Assuming we are talking abouot the same switch: It disconnects the auxiliary battery(s) for storage. Nothing that runs on 12v should work. Best for temporary storage. Batteries should still be removed for long term dead storage.
Dec 17, 2014 | Thor Motor Coach 2013 Daybreak 28PD
How long does charge last, want to charge before giving as a gift
charge to at least 50%. (For storage purposes, so that the battery won't get messed up).
You can tell this by checking the battery indicator (bars, icon or percentage) periodically. If it shows 50% or an icon that shows a battery half-full.
sorry if this was confusing, as I am tired.
Dec 04, 2013 | Cameras
WHEN i CHARGE THE BATTERY, IT NEVER SHOWS IT IS 'FULL' HOWEVER LONG i CHARGE IT
Charging should take maximum of 6hrs. But some phones charges full in 2hr, 3hr, etc...
If your refuses to charge full, after 6hrs, then there is a problem with either your charger or your battery. One of these is the cause of the problem.
So you can have the battery and charge tested on another phone. Maybe that of a friend or family.
I hope the above makes sense to you.
Good luck.
Apr 01, 2011 | Cell Phones
Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my computer...it charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Jun 25, 2009 | Sony Audio Players & Recorders
V262 constantly beeps "low battery" alert
your battery might need to be changed. even if it has a full charger it might not be able to properly charge you phone.
try a new battery.
Mar 06, 2008 | Motorola Mobility V262
Won't hold a charge
It's the battery, over time the amount of power that the battery can store diminishes, and the indicator will still show a full charge, even though it is not fully charged. try getting a new one, from sony, or a 3rd party supplier. ;)
Jan 17, 2008 | Sony Handycam CCD-TRV37 Camcorder
Pride Go Go Elite Traveller Plus 3 Wheel Travel Scooter  Logo
76 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
