Question about Microsoft Windows XP Professional
Warning release the lock switch ,but lock switch is already released
    Problem Solver:
  • 16 Answers
Maybe the swick is stuck or the conection is loose.
Posted on Dec 02, 2012
Trunk release for 98 pont gp no power, can't find the fuse and the switch itself was checked and was good
Check trunk release solenoid for power and ground when applied from switch. If power and ground ok, then release solenoid is the problem in the trunk lock mechanism. If misssing power or ground, then electrical diagnostics will be required
May 15, 2015 | Cars & Trucks
My trunk won't open. What's wrong
Hi Annette, Im AL the owner of Big As Auto Repair.
Annette, if you are already able to get inside the trunk, remove the lever that goes to the lock actuator because the actuator may be locked up. Then see if it will open. NOTE: If the lock solenoid is mounted to the latch this will not work. If that doesn't help, then see if you can remove the bolts that hold the latch to the trunk and open the trunk that way so you can see better what the problem could be. Keep me posted at my auto-repair-website here: http://www.bigasautorepair.com/
Feb 26, 2015 | 2000 Buick Regal
Shift lock release
There should two brake switches located above the brake petal, one is designed to activate the rear brake lamp relay, the second would be the park/neutral safety switch which may be defective and failing to activate the shift handle release relay. You can test this by first turn the ignition key forward then jump the two wires behind the switch, you should then hear the transmission shift handle lock release. If this is heard, the switch has failed and requires replacement.
Dec 22, 2013 | 2008 Honda Civic
How to remove passenger door panel
Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
Remove the window regulator handle, if equipped. (manual windows only)
Remove the front door warning reflector.
Remove the door panel screw (1) through the hole in the door warning reflector opening.
Use a flat bladed tool in order to remove the rear deck release switch bezel.
Disconnect the rear deck release switch.
Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
Remove the lower switch bezel trim screws.
Remove the lower switch bezel trim panel.
Use a flat-bladed tool in order to pry the front door switch bezel upward.
Disconnect:
Power door lock switch connector, if equipped.
Power window switch connector, if equipped.
Power mirror switch connector, if equipped (left side only).
Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Reverse procedure to install
Oct 10, 2011 | 2000 Oldsmobile Alero
Window on drivers side froze and fell down and won't roll back up. How to take door panel off to fix the window
  1. Disconnect the negative battery cable. Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
  2. Remove the window regulator handle, if equipped.
  3. Remove the front door warning reflector.
  4. Remove the door panel screw (1) through the hole in the door warning reflector opening.
  5. Use a flat bladed tool in order to remove the rear deck release switch bezel.
  6. Disconnect the rear deck release switch.
  7. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
  8. Remove the lower switch bezel trim screws.
  9. Remove the lower switch bezel
  10. Use a flat-bladed tool in order to pry the front door switch bezel upward.
  11. Disconnect:
  1. Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Installation Procedure
  1. Install the front door trim panel to the door. Ensure that the retainers are locked into place.
  2. Connect the rear deck release connector.
  3. Install the rear deck release switch bezel. Press the bezel firmly into place.
  4. Install the window regulator handle to the door.
  5. Connect:
  1. Install the front door switch bezel assembly to the front door trim panel.
  2. Install the lower switch bezel trim panel. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the lower switch bezel trim screws.
  4. Install the lower switch bezel trim screw access cover.
  5. Install the door trim panel screw (1) through the hole in the front door warning reflector.
  6. Install the front door warning reflector.
  7. Connect the negative battery cable.
Oct 15, 2010 | 2000 Oldsmobile Alero
Keyless entry not working
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
The battery on my laptop will not come out. The release tab is stuck and no matter what I try it will not budge. Any suggestions?
Run the computer on battery until the battery is dead. Spray the battery bay and release tab with a _LIGHT_ coat of WD-40 and try again. A small screwdriver may help to pry the release out of the way. Too much pressure can break the release. If the battery is working well, you could just live with it in place until replacement time.
Sep 01, 2009 | IBM ThinkPad T40 2373 Notebook
My famalia automatic engine just stop working all on a sudden without warning.car would not engage into any drive ,what is the cause?
if the sollector is stuck that means the safty lock would not release it sould release when you press on the brake pedal if that don't work then the brake light switch is either bad or it doesn't have good contact wiggel the wires and check before replaceing switch
Jul 12, 2009 | 1994 Mazda 323
Microsoft Windows XP Professional Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
