Question about Panasonic PT-56WXF95 56" Rear Projection Television
Panasonic TV My tv is showing a kind of red double vision on everything letters and objects, Kind of has a blur look to it. If you litely tap the side of the tv it will fix its self, but not anymore. Is something loose and can I fix it?
    President:
  • 3,130 Answers
If that was the case, then you first had a loose connection my friend on one of the convergence IC's. But the longer you "tap" the set to correct your problem the more of a chance that now the convergence ICs are bad and will need replacing. these IC's are not plugged into the board, they are soldered. If you have some TV repair knowledge, and have experience soldering and unsoldering on small solid state printed circuit boards, then yes you should have no problem reading a schematic diagram, locating the two convergence IC's and replacing them. There could also maybe a feedback resistor or two that might have went out as a result of the IC's blowing out. Good Luck
Posted on Jun 07, 2007
TV HAS A RED WAVE ACROSS THE BOTTOM CAUSING DOUBLE VISION
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Panasonic PT-56TWD63 56 in. Rear...
Tv shows double vision in blue color. how to fix this problem?
This is a problem with your convergence settings found under your tv's menu. its very easily fixed, you just need to open the setting for convergence and use the arrows on your remote to adjust. inproper convergence can cause either a red or blue haze around almost any object displayed on the tv screen
Apr 14, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
46" PANASONIC TV
Your STK convergence IC's need replaced, not something for the consumer to try and tackle.
Mar 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Panasonic PT-56WXF95 56" Rear Projection Television Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
