Question about Razor Dirt Quad Bike
I bought an after market 5 wire throttle. The wires colors are different from the original. The after market wires are explained. However, I don't know what the original wires specifically cont
I need to know what each wire color on the original 5 wire throttle does.
1998 ford mustang radio color code wiring
The 2 extra wires are for the Boom Box .
Jan 22, 2013 | Cars & Trucks
After market radio for chevy cavalier
Go to your local Autozone or walmart and spend 20 bucks on a install harness.
Aug 07, 2012 | 1999 Chevrolet Cavalier
2004 explorer 4.0 sohc tries to die out at 75 mph any ideas on the problem.
Hello! I suspect a defective Throttle Positioning Sensor (TPS)...Ther are two inside one encapsulated device...See photo below...If you have a voltmeter they can be tested...The TPS is bolted to the throttle body and has a 4 wire connector...Pin 1=signal out..A Gray/White wire...Pin 2=+5 volts...Yellow/White...Pin 3=Ground...Pink/Orange...Pin 4=signal out...Yellow/White..(maybe a different color)...Using two safety pins push the points into the rear of the in-place connector...Into the Pink/Orange and the Gray/White...Set the meter to read 5 volts...Clip the (+) probe to the Gray/White and the (-) probe to the Pink/Orange...Start the engine...Must read less than 1 volt (.85) at idle...As you increase the throttle to full the meter must read 4.5 volts...
Next move safety pin and (+) probe to Pin 4...Perform the same test...Again meter must read 4.5 volts at full throttle...If either reading is in error the TPS is the culprit...Guru...saailer
AIRTEX / WELLS Part # 5S7264...Cost $70
Feb 11, 2012 | 2004 Ford Explorer
I bought a replacement oxygen sensor providing instructions for new part wire color connections. The old and original part bring different color of wires. What should I do?
Return the Sensor
You want an OEM replacement
that is exactly like your old one
Screw it in Tighten a little
and plug in wire connector
Mar 16, 2011 | Chrysler Pacifica Cars & Trucks
Replace egr and even had the computer reflash and still have same code po1404. 1998 gmc 1/2 ton 4x4 with 5.7 angine and autmatic
If you bought an after market EGR valve you need to make sure was identical to your original there are many different ones out. I have customer replaces theirs and come in to find out the one they bought was for a 2.2 S-10. BUt i have also seen a lot of these replaced when it was just a bad harness or broken wire before the connector. The wires are generally pulled over the connector very tight and over time they break inside.
Aug 27, 2010 | GMC K1500 Cars & Trucks
Theres no green wire
modles in the states are usaly different from asian and uk markets if it was a direct import then it will differ from states
Sep 25, 2009 | Hyundai Motor 1999 Elantra
1996 eagle vision radio wiring
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Light Blue
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Pink
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 23, 2009 | 1996 Eagle Talon
2005 PONTIAC GTO gas pedal electrical plug
Connector Part Information
• 7223-9730-30 • 10-Way F (GY) Pin
Wire Color
Circuit No.
Function
BN
1271
Reference Low Signal
WH/BK
1164
5-Volt Reference Signal
L-BU
1162
Throttle Pedal Position Signal
Not Used
5
BU
1161
6
TN
1274
7
PU
1272
8-10
Not Used
Hope that helps, Good Luck
Aug 27, 2008 | 2005 Pontiac GTO
Razor Dirt Quad Bike Logo
100 people viewed this question
Top Razor Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
Betty L Kidd
Betty L Kidd
ray gallant
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
