Question about Belinea 10 17 15 17" LCD Monitor
I need the driver for the Belinea LCD 17" monitor model 10 17 15
I use Windows XP. I can't adjust the resolution. I've try the normal way via Control Panel, Display, tab Setting.
  • Belinea Master
  • 829 Answers
Hi ,Download from the below link
Posted on Jan 11, 2009
You need the correct graphics card driver, monitor drivers are generic
Posted on Mar 30, 2009
Xp driver 1703fps
You don't need a driver for xp. Get Service Pack 3
Apr 24, 2014 | Maxdata Belinea 10 17 25 17" LCD Monitor
Norcent Technologies LM173SB 17 in. Flat Panel LCD Monitor Won't work with Windows 7
I ran into this very problem myself, the issue is that the monitor only supports 1280x1024 resolution MAX. Windows 7 cannot detect this monitor and so it does not know it is limited to this resolution, so Windows 7 is putting out a higher resolution at startup, thus the monitor tries to autodect for a second but then just goes blank because it doesn't understand (and can't display) the signal. The only solution is to use another monitor and adjust the resolution to 1280x1024 or lower, but I run into a problem where as soon as you remove the other monitor and restart, WIndows tries to "plug & play" the monitor all over again at startup. So you're best bet really is a newer monitor unfortunately, I only use my old Norcent monitor with my XP computer.
Aug 29, 2012 | Norcent Technologies LM173SB 17 in. Flat...
Reinstalled (2003) XP and cannot install 1703FP monitor drive, by cd or improve resolution directly. No option available via control panel and not by documentation cd (despite it says to have driver...
What you need to locate is the driver for your video card, could you please provide the model for your base unit / pc and we can locate those for you. Please add them under comments on here.
Jun 01, 2011 | Dell 1703FPs 17" TFT LCD Flat Panel...
I recently reinstalled my windows XP program and added the Dell E173FPc. At the beginning it work perfectly. I then downloaded all the XP updates and restarted several times. I now have a terrible...
Have you tried setting the resolution using display settings in control panel?
Go to control panel search for display. There you will find option to select monitor and resolution.
Oct 01, 2017 | Dell E173FPc 17" TFT LCD Flat Panel...
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Driver for my belinea monitor
Try this?
Jun 11, 2009 | Belinea 19" TFT LCD Monitor
Pop up auto adjust in prograss
I had the same problem with my HP LCD. I'll turn on the monitor and it will run auto adjust and set everything to the max making the screen very bright. What I did was remove the button panel board and put it back. Everything works fine since then.
Jan 09, 2009 | Dell E173FP 17" LCD Monitor
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Belinea 10 17 15 17" LCD Monitor Logo
2,382 people viewed this question
Top Belinea Computers & Internet Experts
David Payne
David Payne
Are you a Belinea Computer and Internet Expert? Answer questions, earn points and help others
