Question about Panasonic TH-42PX50U 42 in. Plasma HDTV
My HDMI is not working . I believe it was shorted out by a power surge. What can I do to fix this problem. My set is a Panasonic TH-42Px5OU. All other video ports are working properly.
    New Friend:
  • 12 Answers
Replace the hdmi cable. I've stepped on an hdmi cable and broke something internally and had similar issues.
Posted on Dec 01, 2012
  • Randy Watson
    Randy Watson Dec 01, 2012
    Actually I swapped cables with another tv and it works fine. I fear it may have fried the board.
  • 1606 Answers
SOURCE: I am trying to connect my macbook pro computer to
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Posted on Oct 13, 2010
Testimonial: "Thank you for giving me another avenue to explore."
  • 91 Answers
SOURCE: I cannot install a new PS3 Slim to a Panasonic
have you told the ps3 you want it to work through the hdmi cable?? it wont automaticly do it
Posted on Apr 24, 2010
radar001
  • 1051 Answers
SOURCE: HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Posted on Dec 17, 2009
welcomejee
  • 10594 Answers
SOURCE: Panasonic TH-42PX60U HDMI stopped working
Please unplug TV from AC outlet and replug it after 5 minutes then check HDMI port.
Posted on Nov 28, 2008
  • 47 Answers
SOURCE: Can't play my PS3 through the Panasonic TH-42PZ800A
your HDMI output is bad
Posted on Jun 14, 2009
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
I have a panasonic viera th-50px75u and i cant get
Try disconnecting all HDMI cables and plugging the TV into a new wall outlet. If the issue is resolved, it may have been caused by a small power surge from either your wall outlet or one of your source devices.
Oct 17, 2013 | Panasonic TH-50PX75U Plasma HDTV
Panasonic plasma flashing red light
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 11, 2013 | Panasonic Silver Tilt/Tilting Wall Mount...
Panasonic TH-58PZ850U, red LED light blinks 6 times..TV will not turn on
Aug 08, 2013 | Panasonic TH-58PZ850U 58 in. HDTV Plasma...
Only one (out of four total) HDMI input is working on my set.
The HDMI switcher IC chips in TVs can be damaged but lighting hits near you house even if the power is protected with a surge protector. The damaging power comes in through the HDMI port and blows the chip out and it can affect just one port or multiple HDMI ports. Your best bet would be to just get a cheap HDMI switcher and use the one working port. The repair on the TV would require placing the control board and would run from $75-150 for parts plus the labor to install it.
Aug 16, 2012 | Televison & Video
I just bought a Panasonic SA-PT480, set it up, step by step per the manual, powered through 2 surge protectors( the second surge protector is used to completely cut power to devices that dont need constant...
I can't find a manual for this thing, which I believe is part of the SC-PT480 package.
I'd plug it straight into a wall outlet for further fault isolation and treat it like it has never worked, no assumptions.
Surge protectors only address outside power surges. Overheating, speaker shorts yada yada can still happen. Effective self-protection circuitry activation need not be preceded by smoke and light shows.
When the audio cut off did the unit also die, or did it look otherwise alive? If the former...
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Maybe a sleep timer clicked it off. Or if it seems to power on but remains silent some other setting like muting, tape monitor got activated. Or the source audio died. Lots of things.
Feb 23, 2011 | Panasonic Audio Players & Recorders
Killed by lightning, have power, no picture...
The warranty does not cover lightning, check if your insurance covers it.
A lightning strike on such panel ( HDMI ) is very difficult to repair and if not impossible.The HDMI connector is hooked to the ground of the TV set so everything could be damaged.
My advice is not to repair.
Aug 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
How to get 5.1 sound from plasma tv to home theater system?
You just need to connect an Audio Out port on the back of your TV to an Audio In port on the back of your JVC box. See what connections you have, I'm sure there are lots of options for you such as HDMI or just normal 2-cord audio cables.
Mar 18, 2009 | Sony VAIO VGP-WKB1 Keyboard
Power light blinks 10 times
You have the same problem i have. My Tv just did the same thing 3 nights ago. I unplugged the set, and let it sit ofr about 6 hours, and then tried it again. It turned on and played, but repeated the problem after about 20 or 30 minutes. So far all my research has led me to believe that its a power supply issue. Problem is, there are 5 boards in the tv with seperate pwer supplies, and the 10 red flashes indicate that its all of them. :-(. Im shopping for a new TV, and It wont be a panasonic this time.
Feb 24, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PX50U 42 in. Plasma HDTV Logo
494 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
