How do you turn off the write protection on a sd micro card. when I formated it with my phone it write protected it and there is nothing on the card. I cant download anything to the card or reformat it. Please help!!!!
I went to menu, tools, memory card, and options but all that showed up was delete, rename, new folder, sort by, delete all, multi delete info, and cancel. What do I do?
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter.
2. Unlock the micro SD through your adapter as shown below.
3. Once done, your micro SD is no longer write protected.
NOTE:
The lock switch doesn't lock the micro SD into the adapter;
The lock switch doesn't lock the data on the micro SD;
The lock switch simply tells the "user" not to write.
It just says "please, don't write me."
I hope this helps.
If you are using it with the SD adaptor, the swith at the side marked lock is not to secure the micro sd card within the adaptor. This is the write protection. If you set this to the 'unlocked' position (up) then you should be able to write files onto it!
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
i found something to fix it. or at least it worked for me http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe Install that, then run the program and CAREFULLY select your card from the formatting list then do a low level format Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Hi , means you connot delete the picture , the only remedy to erase the write protect to format the micro sd , for the next time dont click to write protect .
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me [email protected] or [email protected]
same but the slider does not work
