Question about Dewalt D26441 - Palm Sander, 1/4 Sheet
Where to apply grease
I have got a noisy DeWalt D26441 palm sander, I want to grease inside as i'm replacing the broken base plate so will take it apart and give it a good clean, what sort of grease do I need, where should I apply it and should areas be avoided?
  • Dewalt Master
  • 885 Answers
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
Posted on Dec 04, 2012
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I have a d26441 sander. No instructions. Are the
Do not break anything. Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom and download a user manual for the tool. It should have come with what is called a punch plate to perforate the sandpaper for dust pickup (such as it is) Go there first and you will find everything that you need to use the tool
Posted on Mar 10, 2009
  • 104 Answers
SOURCE: no sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Posted on May 23, 2009
Velcro pad that the sandpaper is fixed to has come off the plate. What's the best glue to use to re-stick the pad with?
You may try a two part epoxy, or gorilla glue. Let dry for a day or two. Sometimes 3m spray adhesive also works. Let tack before sticking together though.
Oct 19, 2012 | Dewalt DW 411 HAND PALM SANDER
Where can I get instsructions for the Dewalt DW411 Palm grip sander and also what type of sand paper do I get to fit it.
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
Oct 05, 2010 | Dewalt DW411 quarter - sheet palm grip...
Dewalt DW433 belt sander stop working, why? While sanding shutters, my sander just stopped. Any fixes?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 02, 2010 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
The motor buzzes slowly, it seems to be labouring and the plate rotates very slowly. Its as if the motor is blocked up inside. I've taken it apart and removed as much fine dust as possible but this hasn't...
sounds to me like the bearings are locking up, you can go to Dewaltservicenet.com and type in your model number and download a parts explosion for this tool so you can see the replacement part numbers. when you had it apart did you see any indication that the field was rubbing on the armature?? I would take a close look at the bearings though.
Jan 23, 2010 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
No sanding action and motor just buzzes
Mar 30, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
Mar 09, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
The disc will not keep spinning
I am assuming you have a 5" pad palm sander. IF pad stops then belt is broken
Mar 05, 2009 | Dewalt Tools & Hardware - Others
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Dewalt D26441 - Palm Sander, 1/4 Sheet Logo
132 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
