Question about HP LaserJet P3005n Printer
How do make cold reset at hp 3005n - HP LaserJet P3005n Printer
2 Suggested Answers
TerryTown
  • 292 Answers
SOURCE: have a hp laserjet 3005n printer, that will not boot up
Thank you for contacting FixYa with your printer inquiry.
Here is the info you requested on a reset. We may have other issues including the formatter.
HP LaserJet 3005 Cold Reset A cold reset unlocks menus that have been previously locked and sets all control panel menu items (including EIO settings) back to the factory defaults. However, it does not clear the values in the SERVICE menu (such as the serial number and page counts).
NOTE Before performing a cold reset: print a menu map and a configuration page. Use the information on the configuration page to reset any customer-set device configuration values that the cold reset procedure changes.
1. Turn the device off. 2. Turn the device on. When the memory count begins, press and hold the [SELECT] button. Continue holding down the [SELECT] button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds. 3. After the message SELECT LANGUAGE appears on the display, press the [UP] button or [DOWN] the button until COLD RESET is highlighted. 4. Press [SELECT] . The device performs a cold reset and then continues its power-on sequence. 5. Check all I/O settings and reset any customer-set device configuration values.
If that fails try this info: The formatter Part # is Q7848-61002
Formatter Questions and answers Forum: http://www.fixyourownprinter.com/forums/laser/54166
Hope this helps helps. Please keep us updated and remember to rate this answer.
Posted on Jun 12, 2011
How to change the DIMM 1 in a HP 3005N
The DIMM chip is located in the formatter board, that cage where the network cable is attached.
Mar 26, 2013 | HP LaserJet P3005n Printer
Hp laserjet 3005n printer continuse printing error comming 49.2f9d
Hello, 49 errors can be troublesome and difficult yo solve, this relates to either an hardware or application error.
For more on 49 errors follow the posted link.
Support 49 Errors CLICKHERE
Feb 01, 2011 | HP LaserJet P3005n Printer
MY HP LJ 3005N PRINTER GIVING 49.2F9D ERROR
Firmware upgrade. www.hp.com/go/ljp3005 firmware
Do it twice. Upgrade the firmware and then do it again. Don't ask.
Oct 13, 2010 | HP LaserJet P3005 Printer
My 3005N makes a grinding noise when printing
Replace the fuser and fuser idler gear RU5-0957-000CN
Feb 05, 2010 | HP Office Equipment & Supplies
57.03 error shows in hp p 3005n laserprinter
.03 identifies it as a right fan error. The suggested remedy for this error is to replace the DC Controller board. Contact HP for replacement information.
Good Luck,
NOLA Tech
Jan 29, 2010 | HP Media Center m7250n (ED842AA) PC...
Have a hp laserjet 3005n printer, that will not boot up. Is there a way to reset it?
Dec 08, 2009 | HP LaserJet P3005n Printer
Noise when printing
Try to work through helpful links here, here, or here. or here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2009 | HP LaserJet P3005n Printer
How do I replace a formatter board on an HP 3005N. It is out of warranty and I don't want to take it to a retailer to fix. Thanks
Hi there Fairly simple process romve the right hand side cover (slide to the back of the printer and lift off) open the formatter board protection cover hindged at the back then disconnect all cables and remove the formatter board Regards AL "alstech"
Jun 15, 2009 | HP LaserJet P3005n Printer
Duplex option is not there.
When you have a P3005n, you probebly see a duplexer unit in the printer, but it will not work, because you haven't P3005dn/P3005X!
Apr 02, 2008 | HP LaserJet P3005n Printer
Hp 3005n error on display
What is the error number that comes up there should be a code that is displayed. Once I have this number I will be able to tell you why you are getting the error and how to fix it.
Thanks J
Jan 21, 2008 | HP LaserJet P3005n Printer
HP LaserJet P3005n Printer Logo
Seeker5211
Seeker5211
