I have the kenmore elite he4t washer and the gray
I have the kenmore elite he4t washer and the gray rubber bladder in the front of washer has came loose how to reapply the spring wire still looks good
5 Suggested Answers
reg501
  • 413 Answers
SOURCE: Kenmore Elite HE4t Washer
Remove three screws in the back that secure the top. Push down on lid and slide to the back.
Posted on Jun 29, 2008
  • 91 Answers
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Posted on Jan 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
Posted on Feb 12, 2009
  • 3741 Answers
SOURCE: Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Posted on May 05, 2009
I have a kenmore he4t washer and the front door
First thing to check is if your door hinge has a sag to it. The next step if there is a sag is try adusting the screws that hold the hinge on the frame of the door sometimes these do come loose. and do require tightening. Folowing confirmation that there is no sag in the hinge your next step would to order a new door latch. If you are not mechanically capable of removing the front section of the machine you should call a technician
Apr 28, 2010 | Kenmore Elite 45986 Front Load Washer
How do get the door to unlock with a Fdl fault, Kenmore elite he4t
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 14, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer HE4t. F DL comes up and washer
1. Unplug washer.
Mar 09, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Rubber gasket around opening
Iserial #15616047cc i want to know how to repair it my self
have a ANANA washer machine model alw 480daw
Jan 27, 2008 | Bosch WFMC 3200 Front Load Washer
Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
