Cannot initialize application ulead video studio se dvd version 10 have changed resolution with same results
Unit is model usb-avcpt . Purchased ftom Sabrent and is listed as a Video DVD Maker USB2.0 Video Capture Creator with Audio. Have installed and uninstalled several times but am unable to get past the "cannot initialize application message. Help!!
SOURCE: Sabrent DVD Maker - USB USB-AVCPT
I just found a solution to the same problem... within the dvd software under the "capture" tab there is a settings button. You have to switch the input from "tv" to "composite". Was going nuts for hours. Hope this helps.
Posted on Jan 16, 2009
SOURCE: sabrent usb avcpt video capture
As you are probably aware the install guide is pretty rough. I had the same problem but did discover Sabrent has a support line (626-336-6363) and after disabling a driver for my ATI video card and some configuration changes it started working and I'm impressed with the quality and cost of this device. Oh By The Way the usb-avcpt also works with Roxio Media Creator 8.
Posted on Apr 01, 2009
smokintdi
  • 7 Answers
SOURCE: EasyCAP Video Adapter with no video
Ok, here is what is going on. The default video setting in control panel> scanners and cameras> syntek 1160 is pal-b it should be NTSC_M. Right click on the Syntek 1160 and click Video Decoder Property. Change it to NTSC_M from Pal. Do this with the unit plugged in or it wont be displayed in the Scanners/Cameras options box. Right away the signal line should rear 1 from 0 with video hooked up. Keeping that setting to stay is my issue right now. I was so excited to figure it out, I had to post. I was about ready to throw the unit away. Its a program driver error. Hope this helps!!!
Posted on May 20, 2009
SOURCE: Ulead Video studio 11 in Vista
i purchased EZGrabber installed it connected it up to my camcorder switched everything on but nothing happened. Tried to uninstall it for to try again but it will not uninstall. Can anybody help, either to have the grabber work or to take it off programmes.
Posted on Sep 17, 2009
  • 4 Answers
SOURCE: EasyCap usb adapter sending images only from vcr. No sound.
while i preview mode there is no sound only image. when you record then playback sound is there.
Posted on Sep 23, 2009
Will usb-avcpt work on windows 10
maybe but possibly not . many things do not work on windows 10
Mar 29, 2016 | Sabrent USB-AVCPT Video Capture
Cannot initialize application The screen resolution is too small to play the video [15034:1:1]
Try to right on your desktop screen .
1. Select ( properties ).
2. Then select ( settings ).
3. Then adjust the color quality from 16bit to 32bit.
4. Adjust the screen resolution to 1024 by 768 pixel.
5. Then select apply.
Try to run ulead again, u should have a video card that support high resolution graphics, 64 to 128 mb Nvidia or so video card. Good day and i hope this could help you my friend.
Aug 18, 2011 | Ulead Videostudio 8 for PC
Usb emp audio device cannot start code 10 error message appears in device manager. also usb device does not show up for a device when I launch video studio
Hi lynnembryant,
Your problem seems to be related to the driver your capture card uses. I would recommend updating them.
Here are the links:
For Windows XP, Vista and 7 32 bits : http://sabrent.com/drivers2/USB-AVCPT-32bit-XP-Vista-Win7.zip
For Windows Vista and 7 64 bits : http://sabrent.com/drivers2/USB-AVCPT-64bit-Vista-Win7.zip
You seem to need another driver as well for the audio, here it is : http://sabrent.com/drivers2/USB-AVCPT-USB-EPM-286x.zip
You might also want to check their support website here : http://sabrent.com/support/.
Cheers!
Mar 01, 2011 | Sabrent USB-AVCPT Video Capture
"cannot initialize application Screen
Try to increase its resolution next to 800X600 or this version maybe works at this settings, version 9 needs 1280X800. Try to adjust the resolution first before you run the application. Or check your driver. Or reinstall ulead with the resolution set to 1280X800.
Hope this gets it working.
Jun 04, 2009 | Ulead Videostudio 8 for PC
Video studio 10
After installing, write the Downloaded file onto a CD, a DVD, or an USB memory stick, and delete the download from Hard disk.
The downloaded file (installer) is no longer needed after the program had been installed and running, if not to reinstall the Ulead software in the future.
Do a backup of the downloaded installer and delete the file from hard disk.
Feb 08, 2009 | Ulead Videostudio 8 for PC
Jan 09, 2009 | Ulead Videostudio 8 for PC
New vista lap top....using my VIDEO STUDIO 8 program
no, this is not, u need to learn the application by user manual or any other help, otherwise use some other application like adobe primeir etc.
Nov 17, 2008 | Ulead Videostudio 8 for PC
Nov 10, 2008 | Sabrent USB-AVCPT Video Capture
Ulead vedio studio 10
Ulead video studio - is not a free software ! U'll only find demo downloads ...
If u really want it u'll be able to download it through sharing software (strongdc, torrents, etc ...). Though if u afford it ! Buy it !
Jan 30, 2008 | Adobe Photoshop 7.0 for PC
Using PV-GS35 as web cam
I use an USB video adapter plus the program:
ulead video studio 8.0 se dvd
and it does work on my skipe.
I hope it helps
Jan 15, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Computers & Internet Logo
296 people viewed this question
David Payne
David Payne
