Does a brand new wd1002faex have to be formatted proir to using a Calvary duplicator
  • 7,627 Answers
I would.
Posted on Dec 02, 2012
Brand new HP laptop keying duplicate letters? Windows 8
Take it back and get a new one. Sounds like bouncing contacts on the keyboard.
Sep 07, 2014 | HP Pavilion Computers & Internet
Can my hard drive duplicator work with files in different formats?
yes, it can work if your source disk is in FAT, 16/32, or NTFS
Jan 23, 2013 | Computers & Internet
Only see 31 MB
It may may need to be formatted. Right click My Computer > Manage > Disc Management. You should see the drive and total space. Like 900 plus GB. Right clicking will give you the option of creating a New Simple Volume, or deleting the tiny 31MB partition and starting from scratch. There is a wizard that will load if you select the drive and refresh. GL
Jan 19, 2013 | Western Digital 1 Tb Caviar Black Sata...
Mac G5, what is pin set up. my computer doesn't see my new hard disq WD1002FAEX
If it is not seeing it then you will need to format it properly for Mac's most hard Drives are pre-formatted for PC's.
You also need to make sure the SATA cable is plugged into the right place on the board.
SATA Hard Drives do not need a pin out. Only IDE drive's have that function.
If this is an addon drive then
Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
  • Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
  • Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
  • Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
  • I got these instructions off ehow.com
    Jul 02, 2011 | Western Digital WD Caviar Black WD1002FAEX...
    What is the specification of this casing?
    Introducing the NEW high-performance stand-alone CD/DVD duplicator systems. These duplicator systems are perfect for heavy production runs since there is no cooling period needed between runs. Beginners and advance users alike will find this system beneficial because of its ease of use speed accuracy and reliability. All it takes is a simple press of a button to get the duplication process started. Let the NEW high-performance stand-alone CD/DVD duplication systems serve as your solution for data backup music video duplications and much more!
    • Supports DVD+/-R DVD+/-RW DVD+/-R Dual Layer CD-R CD-RW blank media standards
    • Intelligent design automatically recognizes the source disc format
    • ?User friendly÷ controller utilizes familiar ?ESC÷ & ?ENT÷ keys with tactile feedback for easy navigation
    • System is upgradeable via firmware
    • Password protection modes prevent unauthorized usage
    • ?Dynamic÷ hard drive partition system saves HDD space by creating partitions according to the image size
    • Allows editing of image and hard drive partition file name
    • Fully stand-alone system - No computers needed!
    Feb 10, 2011 | Sony 20X Burner/1 to 11, Black Casing...
    Calvary 1TB USB 2Bay external hard drive problem
    The problem could be the enclosure, not the drive.
    I would take the drive out of the Calvary enclosure and install it in another one. Hopefully it will come up and you can access your data.
    Jun 15, 2009 | Cavalry Storage Cavalry CADB001U32 1TB...
    When trying to copy a CD, I get the following error message: Warning - Bad Master Disc!
    I assume it means just what it says. The Disc you are trying to copy is faulty?
    Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
    Char S.
    May 27, 2009 | LG 1 to 6 Target CD Duplicator 52x CDRW...
    Targer drive not ready.
    "Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
    "Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
    Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
    "Target drive not ready"
    is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
    or no disc in it at all, and or some sort of incompatible blank media.
    I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
    I ran into the above situations alot.
    I use it as a standalone (not hooked up to any PC etc)
    It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
    Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
    P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
    Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
    Just some tips from someone who's had their player a long time
    Hope this helps anyone in need out : )
    Jun 20, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
    Duplicating songs
    The device has 2 modes of operation MSC and MTP.
    If you put music or playlists on in either mode and then changed modes to add more music, you will inevitably have duplicated your music.
    Best solution is to format the device to remove everything, then pick one mode ant use that one only.
    Best of Luck.
    Oct 12, 2007 | SanDisk Sansa E280 MP3 Player
    Computers & Internet Logo
    26 people viewed this question
    David Payne
    David Payne
