Question about Sony BRAVIA KDL-46W3000 Television
HDMI not always working
The hdmi shows the incoming dvi video for 3 seconds and goes black untill i turn off tv and turn back on. The same senareo turning cable box off on. Sometimes it runs for a couple of hours before vid dissapears.
What's going on. The cable box is a motorola.
  • brianbuy May 11, 2010
    are you using a hd silver comcast cable box ?
  • Mathew F
    Mathew F May 11, 2010
    Have you tried using a different cable on the HDMI port. Im guessing your using a HDMI to DVI cable, which there is alot of problems with. Try getting a HDMI cable and see if it happens with out using your all ready excisting cable
  • 54 Answers
With the tv on, walk up to the cable box and turn it off. using the cable box remote quickly press the red menu key. you should see a white screen with setup information on the screen. the first setting is tv size,that should be 16 x 9. the second should be set to 1080i. and the 4:3 override to 480p. you can change these setting using the up and down arrow keys to select and the left and right to adjust the settings. don't panic if you loose the picture for a moment, it will come back. when you are done, press the menu key again quickly. then turn the cable box on using the power button at the front of the cable box.
Posted on Jan 19, 2009
Problem with HD channels on Elent 40" LCD HD TV
Could be the HDMI bank, try the DVI hook up, you won't have HD but it would give you knowledge.
Apr 25, 2017 | Element Electronics 40 in. LED HDTV
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
Have a jvc 70-inch tv and hdmi isnt working! it just shows picture on screen when connected with hdmi device for 3 second and go and back the same always however with the DVI cable working fine ,but no...
Chances are you have a bad mother board, you can use the composite inputs if your device has them coming out and still get a HD picture, but like Roku doesn't have those , only a HD output
Nov 21, 2017 | Televison & Video
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hook up
Yes, you can! But not straight out of the box. You need to purchase a DVI to HDMI cable adapter. It will convert it so your tv can use it. Here is a link to some:
http://www.connectworld.net/syscon/dvi-to-hdmi-adapters.html
Hope this helps! Please rate me!
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hdmi-av
i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Nov 17, 2007 | Sony Playstation 3 (PS3) Console
No signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Sony BRAVIA KDL-46W3000 Television Logo
156 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
