Question about Panasonic PT-56WXF95 56" Rear Projection Television
Panasonic PT-56WXF95 I'm having a problem with the screen showing red double vision around all object and word. Looks like the picture is blured. If you litely tap the side it would fix but not anymore. Is something loose and can i fix it myself?
    President:
  • 3,130 Answers
Already answered
Posted on Jun 07, 2007
TV HAS A RED WAVE ACROSS THE BOTTOM CAUSING DOUBLE VISION
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Panasonic PT-56TWD63 56 in. Rear...
How to fix when out of focus?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Panasonic PT-51DX80 51" Rear Projection...
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
You can see some more examples and find a fix here
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 20, 2010 | Televison & Video
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Double vission on a HDTV Panasonic
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 15, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT-56WXF90 PICTURE BAD.
service call, sounds like the coverage.
Dec 26, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Panasonic TV
If that was the case, then you first had a loose connection my friend on one of the convergence IC's. But the longer you "tap" the set to correct your problem the more of a chance that now the convergence ICs are bad and will need replacing. these IC's are not plugged into the board, they are soldered. If you have some TV repair knowledge, and have experience soldering and unsoldering on small solid state printed circuit boards, then yes you should have no problem reading a schematic diagram, locating the two convergence IC's and replacing them. There could also maybe a feedback resistor or two that might have went out as a result of the IC's blowing out. Good Luck
Jun 07, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Panasonic PT-56WXF95 56" Rear Projection Television Logo
119 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
