Question about Plumbing
My Coldwater handle came off my Moen Villeta Model #: L84720. I can not figure out how to reattach or how to get the GUTS out of th Hole.
5 Suggested Answers
  • 11 Answers
SOURCE: Moen Villeta 2 handle bathroom faucet, need to disassemble
hold the handle and twist the piece below that doesnt turn, anti-clockwise, it should unsrew and the handle should pull off.
Posted on Feb 11, 2009
  • 2468 Answers
SOURCE: cant shut water off on coldwater side on single leaver fauctt
is there a logo on the top of the handle,if so pry it off and there is a screw there,on some there may be a hex head screw on the back of the handle out of direct sight for looks
Posted on Feb 28, 2010
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
wrightly
  • 140 Answers
SOURCE: Hot water handle got loose
http://www.moen.com/shared/docs/exploded-parts-views/l4720pt.pdf
i just sent you a clarification request. The link above is an exploded parts diagram. You should be able to get some of these parts at lowes or home depot. Especially the cartridge.
No really all you have to do to change them out is turn off the water supply, and use the diagram to tell which parts go on when. I doubt you will be able to get everything from the store. But you can probably get any part on there from the moen website.
I hope this helps. I will be more than happy to help you further if you need it.
Thanks,
Mike
Posted on Jul 27, 2011
Hot water handle got loose then eventually popped off this model Moen L4720 Villeta faucet. Where can I go for detailed repair instructions?
Thanks,
Mike
Jul 27, 2011 | Moen Villeta Chrome Faucet W/ Valve &...
I have a model 4570 2 handle bath room facucet, how do I remove the handles to repair it?
Don't turn the handle, but turn the body counterclockwise untl the handle falls off.
Feb 01, 2011 | Moen & Villeta Two Handle Lavatory Faucet
I have a handle that came off a Moen Villeta 2 handle bathroom faucet. It is not obvious, no set screw etc., of how to attach the handle. Also, the stem that the handle attaches to, seems to have dropped...
Sorry to read about your problem, I hope this helps you out.
under the moen symbol is a set screw
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do you remove the handle on a MOEN T 4570 faucet to replace the cartridge?
Don't turn the handle, but turn the body counterclockwise until the handle falls off.
Oct 31, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do you take a moen bathroom Model #: 84206 apart to fix a drip? Hot water side has a slow drip. Need to replace a seal. How does it come apart?
On the handle it self you should see a red and blue button plug. Remove this and you will see set screw. Remove handle, remember to shut off hot and cold water supplies under sink before you go any further.
Oct 03, 2009 | Moen & Villeta Two Handle Lavatory Faucet
One faucet handle has come off the base.
you have to make or buy a stem puller ----look for a retaining clip also
Jun 22, 2009 | Moen & Villeta Two Handle Lavatory Faucet
Feb 09, 2009 | Moen Plumbing
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
