Question about Lexar Professional High-Speed 2GB Secure Digital Memory Card
How to unlock card??
I put it in my camera and it said memory card error card locked then I turned off the camera and moved the little switch on the side and it said the same thing???
  • betsy30307 Jan 11, 2009
    I actually talked to lexar live support and she informed me that it's not the card it's my camera my camera won't hold the 4 gb only the 2 gb thanks any way though
  • mrstshep16 Oct 08, 2009
    How can i unlock 1GB sd card?
  • 13,433 Answers
Thats exactly how to unlock it.. make sure the switch is on the position closer to the connectors on the bottom of the card, the other position says lock.
Posted on Jan 11, 2009
    Genius:
  • 1,447 Answers
Hi
there should be a little switch on the side of the memory card to lock and unlock it.
Keep us posted.
Cannon s5is powershot as soon as i turn camera on a memory card error comes up and theres no card in it, does same thing when card inserted. it's got to be something in the camera slot, is there a lock in...
On the SD card there is a little switch you can move. It has 2 positions, LOCKED, and UNLOCKED. To make the card available, put the switch in the UNLOCKED position.
Here is an example-
If that doesn't work, try putting the card into a memory card reader, like on your PC or a special USB attachment. If the memory card is recognized, then it might be a problem with your camera.
Mar 01, 2011 | Canon PowerShot S5 IS Digital Camera
Tip
Memory card locked
This is a tip explaining the error, "Memory card locked". We will also give you the resolution for this error. This error, or rather message, is usually the result of the following situations.
Situation 1:
Well, this is usually the problem, on the memory card, there is a little switch on the left side, which can switch between "Lock" or "Unlock".
If you get the display, memory card locked, remove the card from your camera, or USB adapter and have a look at the switch, if it is switched to locked, move the lever top the other side and place it back. This should solve your problem, if not, lets have a look at situation 2.
Situation 2:
Open the card slot of your camera and have a look inside with a bright light/ torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch.
With time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
I really hope this can steer you in the right direction. Please rate accordingly.
Kind regards
Andrea
on Feb 27, 2010 | BenQ DC C740i Digital Camera
I've put in 2 new memory cards and when i turn on the camera I get a message: "memory card is locked"
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Dec 07, 2010 | Canon PowerShot SD1100 IS Digital Camera
Microsd memory card is locked
there is switch lock and unlock on the edge of memory card .
Jul 23, 2010 | SanDisk 2GB microSD Memory Card
Memory card locked, already tried little switch on the side
It may have to be unlocked in the camera settings. My phone has a lock feature for photos, to prevent accidenta erasing.
Jul 17, 2010 | SanDisk 2GB microSD Memory Card
I need to unlock a Sandisk SD card, I've just
If you've already tried the slide switch, see this link for additional things that you can try.
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
Niken coolpix digital camera
Hi there and welcome to FixYa.
Check your card, there is a little switch on the side of the card. One side says locked and the other side says unlocked. Move the switch to unlocked and put it back in and try it again.
Rob
Mar 04, 2009 | Cameras
Memory card problem
Hi and welcome to FixYa.
I'm not sure about your particular instance, but this can happen if you change up cameras or use a card reader.
As for being unable read the memory card, sometimes the card can be switched off by accident. Turn off the camera and remove the card. Look at the side of the card and there will be a little switch. One end says locked (or shows a little picture of a locked lock) and the other end says unlocked (or, shows a little picture of an unlocked lock). Just move the switch to unlocked.
Try that, and let me know with a comment if that doesn't work, othewise, thanks for coming to FixYa!
Rob
Mar 02, 2009 | Kodak EasyShare One Digital Camera
My DSE memory card says 'write protected'
Hi there, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Feb 27, 2009 | Fuji FinePix A340 Digital Camera
Camera no longer working
Your memory card must have had the switch moved from locked to unlocked. To fix this, removed the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says locked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on. Try it and let me know if I can help more.
Feb 17, 2009 | Kodak EasyShare C330 Digital Camera
Lexar Professional High-Speed 2GB Secure Digital Memory Card Logo
563 people viewed this question
Top Lexar Electronics - Others Experts
downhille
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
