Question about iLO (2 GB) MP3 Player
SD FLASH CARD -WRITE PROTECT
SD FLASH CARD IS IN WRITE PROTECT-HOW IT REMOVE WRITE PROTECT?
MAKE SURE THE LOCK IS NOT LOCKED ON IT
Posted on Jan 11, 2009
How can i format write protected micro sd card 32gb....
Slide the write protect tab forward to remove the write protection. You cannot format it while it is write protected. Formatting will erase all data on the card. Install the card into a Windows or MAC and wait for the device to detect and mount the card. Use the appropriate procedure for the machine to format the card. See this procedure for additional step-by-step operations after the write protect tab has been moved.
How to Format an SD Card
Oct 22, 2015 | Electronics - Others
My micro sd card is locked how to unlock
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
Genx usb flash 128 Mg is write protect how i can remove write protect
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My 2GB micro SD card not formatting he say remove your write protect but iam already do this
If it says write-protected, then... there is nothing you can do about it.
It's protected to not be formatted.
Aug 23, 2010 | SanDisk 2GB microSD Memory Card
My memory card is write protected.how to remove it?
Some SD cards have write protect tab on the side but not all do so check for that tab. If it does not have write protect it may be you device you using it with or the memory card as a whole has gone out on you.
1. Check for write protected tab on the sides of the card
2. Check the device (try reformatting it in a card reader)
3. Replace memory stick.
Thanks and please do be considerate when leaveing feedback and ratings today, thanks
May 30, 2010 | SanDisk 1GB microSD Memory Card
Remove write protect on a sd card
There is a switch by the side of the card just switch itup or down.
May 18, 2010 | SanDisk 2GB microSD Memory Card
How to remove write-protection
Dear Friend,
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus.
  • Change the Usb Port(Recommend you to Use Backside Port)
  • Change the Cable
  • Restart PC
  • Still have Problem Change Card Reader..
Hope this Helped you..Thanks for Contacting FixYa...........
May 14, 2010 | PNY 2GB microSD Memory Card
Remove write protection from micro-sd card
  1. Remove the Sandisk SD card from your portable electronic device. Ensure that the SD card can be safely ejected before removing.
  2. Locate the write protect lock. The write protect lock should be on the side opposite the cut-off corner of the SD Card.
  3. Disengage the write protect lock. To do this, gently slide the small switch upward, toward the top of the SD Card. The card should now have write protection disabled.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Mar 03, 2010 | SanDisk 2GB microSD Memory Card
iLO (2 GB) MP3 Player Logo
77 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
