Question about Moen & Villeta Two Handle Lavatory Faucet
My cold water Handle came off on my Moen Villeta Model #: L84720. I can not figure out how to put it back on, or how to take the GUTS out to move forward.
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
  • 115 Answers
SOURCE: low hot water pressure in kitchen faucet
this is fun, you probably have some rust or lime build up in faucet, most of these single handles you have to remove handle setscrew usually small allen wrench. shut off water supply first!!! next the barrel should be held on by a screw remove and lift barrel out you should now be able to see build up clean and reassemble if you are not confident with this call a plumber good luck
Posted on Oct 14, 2009
motor1258
  • 6674 Answers
SOURCE: waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Posted on Jan 06, 2010
Testimonial: " Thank you...The plumber put it in wrong.."
radar001
  • 1051 Answers
SOURCE: How do I repair a leaky Moen faucet handle. When I
It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
Posted on Jan 14, 2010
  • 8 Answers
SOURCE: Step by step instructions for Moen 82496CBN
You need to loosen the two screws that attach the faceplate to the control valve on the outside of the shower stall. You should be able to pull the valve away from the stall and place a one or two inch board between the valve and the shower stall as a shim. Vary the thickness of the shim until you are flush with the handle, then secure the shim.
Posted on Apr 04, 2010
Hot water handle got loose then eventually popped off this model Moen L4720 Villeta faucet. Where can I go for detailed repair instructions?
http://www.moen.com/shared/docs/exploded-parts-views/l4720pt.pdf
i just sent you a clarification request. The link above is an exploded parts diagram. You should be able to get some of these parts at lowes or home depot. Especially the cartridge.
No really all you have to do to change them out is turn off the water supply, and use the diagram to tell which parts go on when. I doubt you will be able to get everything from the store. But you can probably get any part on there from the moen website.
I hope this helps. I will be more than happy to help you further if you need it.
Thanks,
Mike
Jul 27, 2011 | Moen Villeta Chrome Faucet W/ Valve &...
I have a model 4570 2 handle bath room facucet, how do I remove the handles to repair it?
Don't turn the handle, but turn the body counterclockwise untl the handle falls off.
Feb 01, 2011 | Moen & Villeta Two Handle Lavatory Faucet
I have a handle that came off a Moen Villeta 2 handle bathroom faucet. It is not obvious, no set screw etc., of how to attach the handle. Also, the stem that the handle attaches to, seems to have dropped...
Sorry to read about your problem, I hope this helps you out.
under the moen symbol is a set screw
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
My moen 2 handle faucet one handle came off. my model # is t4570, How can I get it back on? This handle doesn't have a screw a top.
with the handle placed over top,as if it where in the off position start threading (screwing) it back down, while holding the lever in the closed position.as you screw down you will feel it engage the teeth on the stem,it may take a few attempt's,you may have to "play"around w/it to get right position.
Jan 02, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do you take a moen bathroom Model #: 84206 apart to fix a drip? Hot water side has a slow drip. Need to replace a seal. How does it come apart?
On the handle it self you should see a red and blue button plug. Remove this and you will see set screw. Remove handle, remember to shut off hot and cold water supplies under sink before you go any further.
Oct 03, 2009 | Moen & Villeta Two Handle Lavatory Faucet
One faucet handle has come off the base.
you have to make or buy a stem puller ----look for a retaining clip also
Jun 22, 2009 | Moen & Villeta Two Handle Lavatory Faucet
Cannot get the cartridge out of the moen sh lav faucet..no cartridge tool, what can I use to get the cartridge out???
There is a small U clip that holds the cartridge in. It just slides up or down. Some Moen cartridges are very difficult to remove, they can be corroded inside "almost fused" it is best that you get a moen cartridge puller. Lowe's has them. If you decide to tackle this job make sure the water is off, and when you pull the cartrige remember the direction it came out. If you put it in backwards your cold will be hot, and your hot will be cold!
Jan 24, 2009 | Moen & Villeta Two Handle Lavatory Faucet
Moen & Villeta Two Handle Lavatory Faucet  Logo
78 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
