Question about Dishwashers
I have Bosch DW, logixx model, it seems that its optical sensor is really dirty, is that any way to clean it?Does it need to be cleaned?
SOURCE: Bosch SHX46A dishwasher
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Posted on Dec 02, 2007
Master_Tech
  • 770 Answers
SOURCE: Miele Dishwasher G856 SC cleaning assistance
Yes run a cycle with 2 cups of vinegar to flush it out
Posted on Mar 15, 2008
  • 677 Answers
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Posted on Apr 10, 2008
Bfsas1
  • 258 Answers
SOURCE: clogged dishwasher drain?
clean the filter, check the water inlet and outlets for blockages
Posted on Jun 29, 2009
  • 457 Answers
SOURCE: My Bosch logixx dishwasher is sticking on 1 minute
100% add the jet dry until it is completetly filled then close the dispenser door and lower then raise the door.repeat this at least three times then check and fill if you can still add more. then after doing that b4 you start the machine run the hot water to get the right temp. when the water is hot enough then start the machine.
Posted on Mar 03, 2010
Yellow light keep coming on when i try to make a cu of coffee
the optical sensor that reads the bar code could be dirty. My Tassimo sensor also needs to be "wet" before the disc is inserted to work properly. Seems that the plastic of the sensor has started to degrade and clouded over. When you clean the sensor just use soap and water. Nothing abrasive.
Feb 22, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Intermittently Operating With Little or No Water
Most likely the water level detector (the sensor that tells the dishwasher to stop taking more water) is failing. It is giving early signals which confuses the dishwasher and it turns water off. Most of the time these problems are linked to grime collecting in the inside of dishwasher.
You can clean it by using a dishwasher cleaning powder. Follow instructions on satchet. YOu may have to manually fill the dishwasher before starting it. If this cleaning does not fix it, then you may have to call the technician. You may be under warranty on this (hopefully)
Nov 11, 2009 | Bosch 24 in. SGS09L02 Logixx Built-in...
I need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Aug 31, 2009 | Bosch Washing Machines
Clogged dishwasher drain?
Jun 29, 2009 | Bosch SHU9915UC Dishwasher
I actually don't know what type of Bosch I have. I know that is a problem, but maybe you can still help. It has a simple panel that says: Pot Scrubber, regular wash, quick wash, rinse and hold. When I turn...
On a Bosch dw, it has a light sensor to sense soil in the water.. if the control feels that the water going through the sensor is not clean/ or clean it will add or minus time..one thing you can do is make sure that your drain line from dw to sink drain is cleared of debris.. also, make sure you clean the filter at bottom of dw and make sure its reinstall correctly if you haven't already do so.. if your dw finish the cycle and come out clean, then the time on your dw is fine,, but if it don't finish and come out dirty.. then, it could be something other, but don't know til I get the full details on problem.. help this will do it for ya.. good luck.. mike
Jan 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh logixx
Click on your model number above (below FIXYA ) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Feb 24, 2008 | Bosch Logixx WFT 2806 Front Load...
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
Top Dishwashers Experts
