Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipment. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
SOURCE: Forgot my access code for philips tv model 36pt71b129
Try withn ur remote 062596+staus button with no pauses The menu that comes up should the option to put set back to default and that may do it. R.A.
SOURCE: Hi, I need the parental code to unblock
To solve this problem you will have to contact the manufacturer of the TV. Some TVs are made so that an omnipotence v-chip password can be used to unlock the set in cases where the password has been lost or forgotten. However, only the manufacturer would have access to this information. It isn't available in the public domain.
Also, if you never set the v-chip in the first place, your unit may need repair. Spontaneous activation of a v-chip lock is an indication that a problem has developed with the firmware of the device. The firmware is like the software that allows a piece of electronics to have menus, graphics, on screen displays, as well as the v-chip feature. Your unit may need a firmware upgrade.
But starting with a call to the manufacturer is the first step to fixing this particular issue.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: access code forgotten need to unblock and restore channels
With the remote you can enter a code twice to reset (see pg. 15 of the manual below). It's possible that you can program a universal remote to use the buttons needed to reprogram.
http://www.usersmanualguide.com/philips/tv__4_3_-_tv_medium_20-24_inch/19ps50s
SOURCE: HOW DO I UNBLOCK A CHANNELS ON MY 2000 PHILIPS
May I ge tthe model # of the tv to help you more.
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Read more: http://wiki.answers.com/Q/How_do_you_unlock_a_Phillips_TV_using_the_on-screen_menu#ixzz1eP9NktX3
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
