Question about Whirlpool Dryers
Estate dryer modle TEDS680EQ1 turns on but wont get hot
Turns on but wont get hot
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Check all the thermostats for continuity.
Posted on Dec 02, 2012
  • 185 Answers
SOURCE: Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Posted on Mar 25, 2008
  • 1073 Answers
SOURCE: wont blow hot air
check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
Posted on May 07, 2008
docjohn174
  • 943 Answers
SOURCE: estate teds680eq1
hi thanks for the question i would check the thermal fuse located at the back of the dryer remove back panel you will see on the air duct a small piece with one screw holding it on 2 blue wires going to it replace this part but also vacuum the venting and the rest of the dryer as this fuse will fail again if venting is not right thanks the appliance doc
Posted on Sep 22, 2008
  • 6 Answers
heating element failure 30 bucks and an hour of labor
Posted on Jan 14, 2009
RepairNinja
  • 98 Answers
SOURCE: whirlpool estate electric dryer model teds680eq1
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Posted on Apr 19, 2010
Turns on wont heat up TEDS680EQ1
Check all of the thermostats for continuity.
Dec 01, 2012 | Estate Dryers
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
Apr 15, 2010 | Whirlpool Dryers
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
Oct 18, 2009 | Estate TEDS840JQ Electric Dryer
Wont blow hot air
Jan 14, 2009 | Dryers
Estate teds680eq1
Sep 22, 2008 | Estate TEDS740JQ Electric Dryer
Wont blow hot air
May 07, 2008 | Estate EED4300SQ Dryer
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Dryers Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
