WINDOWS WILL NOT START UP
SCREEN SAYS POWER LOSS BUT STILL WON`T START WHEN I PRESS SAFE MODE START UP.STOP; 0X000000ED (0X8A1C9900,0XC0000006,0X00000000,0X00000000) COMES UP.
  • 7,627 Answers
Unplug, remove battery, leave battery out, plug in. Try a system restore/recovery.
Posted on Dec 02, 2012
crayzeetrayn
  • 837 Answers
SOURCE: stop code 0x000000ed going into power saving mode and shutting of
Read this MS help
http://support.microsoft.com/kb/315403
Posted on Nov 23, 2008
  • 148 Answers
SOURCE: computer won't boot into windows
The event of you inserting a DVD is unlikely to have anything to do with this problem. Probably just a coincidence that it happened after you did so. Hard drives die eventually and more frequently so in laptops.  I'm afraid you will have to bite the bullet and replace the hard drive.
Posted on Dec 11, 2008
SOURCE: unmountable boot volume
Hi
It looks you have a bad hard drive. Have you tried changing it? If not, try it. Regards.
Posted on Dec 31, 2008
  • 3940 Answers
SOURCE: Windows Vista Start up problem, reboots automatically.
Boot to recovery console using XP CD, run CHKDSK /R and see if that resolves.
If no go, try a reinstall of windows, if still no go, then replace HDD
Posted on Sep 29, 2009
  • 76 Answers
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Posted on Oct 08, 2009
0f00:065d
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 03, 2012 | Dell Inspiron Mini 10 Notebook
Stop error code 0x000000ED, dell inspiron mini 10 no disk drive. No recovery or repair disk.
http://www.wiki-errors.com/download.php try safe mode first turn off then turn on press f8 when u turn thhis will take you to safe mode screen try the LAST GOOD CONFIGERATION hopefully this will fix you problem other that click the link
Jul 28, 2011 | Computers & Internet
Is there another way to have my T3500 run in safe mode other than F8...When I press F8 while my computer is booting up it gives me a blank screen.
If you stop windows from booting up all the way by holding down the power button during the "loading windows" screen, until it turns off. Start it back up and before windows loads it will give you a menu, with options like "start windows in safe mode with networking" or "safe mode with command prompt"
May 03, 2011 | Dell Precision WorkStation T3500/ T5500/...
Hi, Everytime I turn on my DELL Dimension 5150 I am faced with the following message: A problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE...
This sounds like it can not mount your boot file from hard drive which needs to load windows. Sometimes this will happen if you leave a floppy, cd or some kinda usb flash drive in computer when rebooting and it does not happen always. I would try to boot in to safe mode as message is saying. To boot in to safe mode modet computers use F8 key. Turn off your pc and then as soon as you push power button start tapping key F8 located on top of keyboard. You can stop once you get screen that says Advanced startup menu. Choose option Safe mode and press enter. You will need to use arrows to make selection. Once you choose safe mode wait for the loading to be done and then choose ether your windows name or Administrator. Once in safe mode you will get error message just ignore it and press yes. When windwos comes up try to do a restore to previous date. Go to start-programs-accessories-system tools-system restore.in system restore choose restore to earlier time and on the calendar choose date that your computer was working fine. I usually go even week prior to when computer stopped working. Your data will be saved but if you have installed some programs you might have to reinstall them. Hope this helps.
Nov 06, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Stop 0x000000ED (UNMOUNTABLE_BOOT_VOLUME)
Hmm seen this a few times. This is most commonly caused by your NTFS format layering being corrupted. Meaning that the partition was either not completed when u loaded the operating system or the format has been corrupted from "hard shut downs" This is turning the pc off with the power button instead of going to "start" button and doing a soft shut down. U can try retrieving the format back but u will have programs that no longer responde. Easiest way to solve the issue is reloading your operating system.
Jun 24, 2010 | Dell Inspiron Mini 10 Notebook
Unmountable_boot_volume error code stop:0x000000ed willnot go past this point how do i enter setup
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Feb 22, 2010 | Dell Dimension E310 PC Desktop
Sep 28, 2009 | Dell Inspiron 1525 Notebook
Since yesterday, cannot boot up my PB IMEDIA 1529 in XP. I get a screen message to say that Windows has been shut down to prevent damage to my computer. Trying to boot up using Safe Mode ends up with the...
Boot your system in safe mode then check, its booting or not, if boots restore it to some previous date, or change the RAM then check
please rate this solution i appreciate it
Nov 01, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
