Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
I have a JVC-48WP74 rear projection TV. I had sears come out and they ID'd the problem as convergence and said I need a new STK392-110 and a 1.8 ohm 1 watt resistor that was blown. I replaced both STKs and the resistor and see absolutely no difference. I went to set up and did the auto convergence and the bottom line, the TV is just as it before I tried to fix it. Where else do I look now for fixing it???
  • JVC Master
  • 8,617 Answers
MY JVC TV SHOW GREEN RED AND BLUE
Thats caused by the convergence ICs and low ohm resistors. Very common problem with all rear projections. You can get the JVC convergence repair kit for your model from www.tvrepairworld.com the kit contains the ICs, Resistors and the CD with repair instructions.
Jun 16, 2011 | JVC AV-48WP74 48" Rear Projection...
Cannot adjust the vertical red lines in convergence
converge stk's failing replace and check always check the big resisters for ohms replace even if they read off by 1 ohm any deveation here is critical to the performance.
Feb 06, 2011 | JVC AV-48WP74 48" Rear Projection...
I have a JVC AV-48WP74 48 in. Rear Projection
Must know basic soldering and have tools like soldering iron,a desoldering pump or desoldering witchs to replaced parts on the tv convergencce board.U have none of these tools devices and never solder bsfore,better hire the tv tech. to do the job.Cost estimate 300-350 for parts and labors.Tries wesite like Tvrepairworld.com,Tvrepairkits.com to buy a whole convergence kit,to do it ur self,if u can?
Jul 25, 2010 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 convergence
The ICs are most likely defective if the old ones allow the set to power up.
Nov 20, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 BLUE CONVERGENCE ADJUSTMENT PROBLEM
Make sure you bought genuine Sanyo chips...if not goto www.TvRepairKits.com and get theirs.
Aug 05, 2009 | JVC AV-48WP74 48" Rear Projection...
I have a jvc av48wp30 tv and need a wire diagram
Looking the convergence board from the side of the resistors (The chips will be behind the resistors), you have from de left to right:
1.5 ohms, 150ohms, 220ohms, 2.2ohms, 3.3 ohms, 220ohms, 1.8ohms, 220ohms, 150ohms, 150ohms, 1.5ohms, and dispose horizontal in relation of the other resistors (the one near to the Ic is 2.2ohms and the other is 220ohms).
Hope this helps...
Feb 02, 2009 | JVC AV-48WP74 48" Rear Projection...
Convergence problem
this convergence repair kit will apply to your model and they include step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kp53hs30/cName/sony
Jan 11, 2009 | JVC AV-48WP74 48" Rear Projection...
JVC MODEL AV-48WP74
Convergence Issues Both STK392-110 ICs and possibly the 1.8 ohm and 1.5 ohm 1 watt convergence resistors as well. You can get replacement parts at the following link and they provide free instalation instructions
Jun 20, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48 in
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | JVC AV-48WP74 48" Rear Projection...
Convergance Board JVC AV-48WP74
it will have a large heatsink with at least two large IC with the numbers STK392-xxxx
Jan 09, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
