Question about Refrigerators
Model gsl25jfpd bs ge fridge drain opening in deep freeze leaks on floor
Fridge leaks water on floor drain tube is leaking or unhooked need to know how to reinstall
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
  • 583 Answers
SOURCE: leaking freezer
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says ?energy saver? or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved. please do not forget to rate the solution.thanks.
Posted on Jun 12, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 17, 2009
woodchuck789
  • 4070 Answers
SOURCE: How do I unclog defrost drain on a model TBX18W?
Posted on Sep 26, 2009
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Refrigerator ge profile model TFH27PR water leaking onto floor
Hi this problem could arise due to various reasons so lets find out what could it be the cause.
1)In the back of your freezer compartment is the drain hole. It's very common in GE for the drain to freeze up. With the drain hole plugged up, your freezer will continue to defrost the evaporator, but not the water in the drain hole. So the water builds and freezes, builds and freezes until it eventually overflows into the air diffuser for the fridge causing the leaky fridge problem."Heat Probe" that can be installed.This will prevent water from freezing up in the drain hole allowing it to drain as designed
2)Inspect the door seals and the sides of the refrigerator around the doors. If you see any beads of water or moisture, then the door seals may be failing to create an air tight seal which causes the cold air from the refrigerator to escape and form condensation around the doors. Sometimes you can solve this problem by applying a light film of gasket lubricant to the existing seals or just cleaning them of any debris with a warm soapy rag. If they still don't seal well after you apply lubricant, or clean them, you may need to replace the entire seal assembly.
3) If the water is coming from the freezer but you think that the defrost drain pipe is clear, then it may be coming from the ice maker. Check the ice maker for cracks in the unit's body or a misalignment of the water supply line. Make sure that the water supply spout in the freezer lines up with the ice maker's water supply cup.
4)Check the ice maker copper water supply line, your ice maker water filter, and the plastic ice maker water supply tube for any cracks, splits or connection leaks. If you find any leaks, remove the leaking part and obtain a replacement at the hardware store.
5)Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
6)If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Note:Switch you Refrigerators for more than 8 hours and let the frost melt fully use hair dryer and now switch on and check you are getting leak.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 09, 2010 | GE Refrigerators
GE Refrig. Water leaking on floor after ice maker stopped
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
Jul 16, 2010 | GE GSH25JFR Side by Side Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Amana Model #TX20NBW FREEZES food in the fridge AND leaks water
Sounds as if the thermostat setting is too high.
Not a good idea to pour warm water into the fridge while its going, but then again.Most drain tubes exit over the compressor into a container sitting atop it. But I've since learned there are now fridges that don't have compressors now? You should also check the door seals, you can do this with a sheet/piece of newspaper
inserted between the door and fridge, go around both doors, you'll soon know if the seals need replacing.
Oct 03, 2009 | Amana ATB2135HR Top Freezer Refrigerator
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Clogged fridge drain tube
Oct 07, 2007 | Refrigerators
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
