Question about Bosch Nexxt WTMC 6300 Electric Dryer
Dryer sounds like a machine gun when running. want to open it and repair
Thumping machine gun sound
If you've never worked in electronics this is not the way to start unfortunately. You say it was spilled on the power plug end of the cord. That should haven't created the issue. Plug it into an unharmed outlet and see if the issue remains. Make sure the plug isn't still contaminated before you try. If the issue persists you will have to decide if the cost of repair is more reasonable than replacing it outright. Your issue sounds similar to a term known as "motor boating". I would guess the power supply is cycling off and on quickly causing the sound you hear. Due to the way these things operate it could be any one of several things. Advice is to not let it continue this for very long or the whole thing will fail making it too costly to repair, turning it into a great table lamp stand!
May 21, 2016 | Audio Players & Recorders
Machine makes a loud buzzing sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is making a knocking sound like machine gun
remove front of fryer and see if anything is in fan.
Nov 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Kenmore 80 series electric dryer will not turn off - continues to run thru cycles - must leave door open in order to turn off- cost wise..it itworth having fixed or look into purchasing a new dryer?
It sounds like the timer is bad. Easy to replace and cheap. Maybe 15-30 dollars for the new one. Not difficult to install yourself, just open up the top console and unscrew the old on and slap the new one in. Takes maybe 15 minutes. Just be careful to put all the wires in the same spot as the old one. Even if you have a repair guy come and do it it will be much cheaper to fix than get a new machine.
Dec 14, 2009 | Kenmore 659 Electric Dryer
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Bosch Nexxt WTMC 6300 Electric Dryer Logo
65 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
